How Do I Replace The Fake Fuel Door?
Old Apr 15, 2007 | 06:55 PM
Jon_Purdy's Avatar
How do I replace the fake fuel door on the trunk lid? Earlier today, whilst trying to remove dried up wax, I put a hefty scratch in it. It's not going to be noticeable to most people but I know it's there and it has to go. I have a replacement on its way, just need to know how to remove the scratched one.
Thanks in advance for your help.
Jon
Old Apr 15, 2007 | 07:01 PM
FLAstangx3's Avatar
use a pick first. Pry up from the keyhole. take your time and work it loose. As it starts to lift, just SLOWLY pull it back and downward. The tape covers the entire underside of the cap, so take your time. It really is easy though. Soooo, are you going SHR or back to stock. It is an opportunity you know.
Old Apr 15, 2007 | 07:09 PM
Jon_Purdy's Avatar
Thanks for the quick reply. Going back to stock. Just curious, would heating the area with a hair dryer help?
Jon
Old Apr 15, 2007 | 07:15 PM
FLAstangx3's Avatar
Little heat from the blow dryer will never hurt it. Mine was fairly new, so it was not a problem at all for me. You might want to get a small flathead srewdriver also for prying it loose from inside the keyhole area, once you loosen it with the pick.
Old Apr 15, 2007 | 07:26 PM
DavidM's Avatar
I used fishing string in a sawing motion to cut thru the old adhesive. It does come loose quite easy though after you get it moving.
Old Apr 17, 2007 | 08:27 PM
DynamicmustangGT's Avatar
I used a blow blowdryer and adhesive remover that is meant for car paint, such as a professional body shop would have
Old Apr 18, 2007 | 02:40 AM
G.T's Avatar
G.T
it's been over 6 months, but i REALLY think it's also held down by 2 screws!
you'll have to remove the luggage compartment trim panel (careful that light gets REALLY HOT)
remove the 2 screws holding the trunk lid lock cylinder
then proceed to pry off the fake gas cap as suggested
EDIT: well i could have sworn mine had screws.. well apparently not
Old Apr 18, 2007 | 06:12 AM
FLAstangx3's Avatar
NOPE!! There are two pins on the faux cap, similar to on the GT emblems, but NOT screws.
Different methods are abundant. Depends on what you really want to acomplish. I my particular case, and I think here also, was to JUST repalce the cap itself, and NOT the removal of the adheasive ring.
Old Apr 18, 2007 | 10:47 AM
sound wave's Avatar
yeah there are no screws. if you buy the shr replacement, it comes with two screws, but the original one doesnt use any.
Old Apr 19, 2007 | 10:04 AM
sodaman's Avatar
Man why would you go back to stock when you could get a silver horse racing emblem, looks functional like the older styles and blows stock away. You can also have the lettering painted etc. Hopefully you will change your mind, they got great stuff. good luck
removal is very easy just carefully use a screwdriver or pick and go to the inside of the key hole area and very slowly pry backwards until the whole thing starts to pry away, take your time and all is well.
kponypower
Jun 17, 2020 07:17 AM
trackpack13gt
Jul 25, 2017 05:29 PM
09-gt/cs
Oct 15, 2015 10:03 AM
trackpack13gt
Oct 2, 2015 08:20 PM
