Help:HD upper Strut mounts for GT ragtop??
Help: Are HD upper Strut mounts really needed??
Planning my winter upgrades, which will include lowering springs (more than likely Steeda Ultralites) for my 07 GT vert., and wondering if I will need the HD upper strut mount? I have read several places that the lowering springs could cause some periodic popping, but some of it was due an older style mount that was addressed on the coupes (just not on the ragtops). I also plan to add an adjustable panhardbar/brace, adj. LCAs and some good shocks/struts to make things a little tighter.
So my question is... are these something I should invest in or not needed/worth the investment? Asking because I found a good deal on a set of Steeda (HD upper mounts) and need to move on them today.
Thanks in advance for any help!
Thanks for the input. I will get them ordered tonight!
But that means I will need to order some other goodies as well. Man, finding this forum is really starting to hit my savings hard!
http://forums.bradbarnett.net/showth...ht=strut+mount
There are very Few Mod Topics which have Not Been Discussed on TMS. Check the Search Feature and you May Find More Info than you Ever Dreamed of.
KC
KC
I bought the GT500 strut mounts months ago... not a peep out of them and they're only $75 vs paying 200+ for a set of aftermarket. Only reason I could see getting the aftermarkets is for more camber adjustment, although all you really need is +/- 2 degrees which you can get out of camber bolts and they're easier to adjust.
robjh22
9/8/15 12:31 PM
