Headlight removal for ram air at track?
Old Oct 9, 2006 | 02:09 PM
SixtySix's Avatar
I see the strawman has returned
Old Oct 9, 2006 | 05:59 PM
GT John's Avatar
Originally Posted by TBone69
I'm wondering if anyone has removed their headlight at the track to provide a little extra "cold" air to their air kit.
Being in close proximity to JDM I picked up their air kit and a C&L racer intake tube to replace the stock elbow and of course loaded the matching tune with my XCAL2. This thing rocks!
The car sounds great and has a lot more kick! I am going to the drag strip to test out the new mods in the next week or so and was wondering if anyone has removed the drivers side headlight to provide a little ram air effect. If so did you see improved ET's?
Also what is involved in removing the headlight assembly?
Tbone69
If you had gone in this direction you wouldnt have to remove anything.
Available from WMSRacing.com
Attached Thumbnails Headlight removal for ram air at track?-p1000101-small-.jpg
Old Oct 9, 2006 | 06:02 PM
mikem's Avatar
Originally Posted by max2000jp
Please explain because you are refuting the laws of physics. Again, air travels the path of least resistance. Pickup a Physics or Aerodynamics book if you don't believe me.
Ok Einstein,At 80MPH with your window down is more air coming in your window or going buy it??????????
I guess we should just rip all our lights out and bumper and etc.Man i should be in the 9,s after that acording to you......
Old Oct 9, 2006 | 06:18 PM
max2000jp's Avatar
Einstein would frown at your knowledge of simple science. Open and close your window. Which one allows are to travel in? Same general concept in relation to the headlight. I am not saying it's going to be hurricane force winds are going to suddenly form in front of the headlight area, but there will definetly be fresh ambient air pushed into the area where the headlight assb. was.
Old Oct 9, 2006 | 07:11 PM
mikem's Avatar
All depends on the pressures.There is a turning Vortex in front of the light area acording to tests already done in the Windtunnel.
Old Oct 9, 2006 | 07:20 PM
max2000jp's Avatar
Might be a bit different if they removed the headlight. It's too big of hassle on this car, but on others it's simple and works pretty effectively.
Old Oct 9, 2006 | 08:05 PM
karman's Avatar
I've been thinking of trying an under bumper air scoop and some ducting to plumb it into the new heat sheild/box
Lets go back to the obvious so we can actually do some good.
Old Oct 10, 2006 | 05:49 AM
94tbird's Avatar
the joys of TMS. no wonder so many switched
if you want to introdune the most air possible into your intake, Ram Air is not the method you want. You will gain much more air under the hood with a Cowl induction hood than Ram Air. Hence why most race cars and cars you see at the track, the serious ones, have cowl hoods. if you want the added air, get a cowl hood and create a duct for the air to travel to the filter. this is definately better than the headlight thing being discussed above, which doesnt work.
Ecostang
Nov 3, 2022 08:50 PM
redrock35
05-09 Exterior Modifications
Jul 31, 2016 08:50 PM
JTB
Motorsports
Sep 3, 2015 10:50 AM
Sep 1, 2015 01:19 PM
ststang
Aug 23, 2015 11:58 PM
