Granatelli Turbo Install
Old Nov 8, 2007 | 07:14 AM
  #81
Wrapping looks good Tom!
Almost too nice to to put under the car!
Old Nov 8, 2007 | 07:26 AM
  #82
89Trooper's Avatar
Thanks! It turned out better than I expected.
I bet J.R. and the rest at Granatelli can wrap them quick - what you see there took me 3 hours.
Old Nov 8, 2007 | 09:16 AM
  #83
turbo05gt's Avatar
You can tell you took your time well worth it
Old Nov 8, 2007 | 09:55 AM
  #84
jayguy's Avatar
I've seen wire (safetywire I think) used on wrap before, it's smaller and hides better, but I don't think there's any problem with hose clamps either. And like you said, they'll be coated and won't be that noticable anyway.
Great job, nice looking cat , and I can't wait to see the finished product.
Old Nov 8, 2007 | 10:25 AM
  #85
turbo05gt's Avatar
He could always paint them black too
Old Nov 8, 2007 | 10:31 AM
  #86
89Trooper's Avatar
Thanks guys!
The silicone coating is black, so it will all blend together.
I'm going to spray some spare pieces of wrap tonight to see how the coating looks. I'm thinking about NOT coating them now since they look so good, but I probably will.
Old Nov 8, 2007 | 01:42 PM
  #87
Granatelli's Avatar
Former Vendor
Originally Posted by turbo05gt
Hmm, but what about when the car is off? Im here in Miami would the humidity here cause issues? Mt hot parts are already coated would I benefit from wrapping?
YES - The wrap traps heat in the pipe and drops underhood temps - period. Moister is a non issue
Old Nov 8, 2007 | 01:44 PM
  #88
Granatelli's Avatar
Former Vendor
Originally Posted by philster2003
Tom do the hose clamps stay (permanent) Or will you take them off when its finished? Not sure I like the looks of the clamps, if you need something to keep the ends from unraveling isn't there another less noticeable way?
Nice wrapping Tom, the wrap looks OK to me, and when painted should blend nicely. So far so good Tom, should be a big weekend for the install, can't wait for the pics
You can also use saftey wire. A thin piano string type cable they is hardly visable
Old Nov 8, 2007 | 05:08 PM
  #89
89Trooper's Avatar
Here's a test piece that I coated. I think it looks really good, so I'm going to coat the rest of the exhaust pipes the same way.
Attachment 35289 The hose clamps are well hidden... do you approve, Phil?
I can still loosen and rotate the hose clamps if needed to hide the screw part.
I also installed the blow-off valve on the intake tube that runs between the turbo and the intercooler:
Attachment 35290 An O-ring is installed, and then the valve is held in place with a C-clamp.
The vacuum line runs up and tees into the fuel pressure regulator's vacuum line. I will also tee the boost/vacuum gauge off this line to get an accurate reading to the gauge.
I'm still not 100% sure what the difference is between the blow-off valve and the wastegate.
I know the blow-off valve is vacuum controlled and the wastegate is controlled by the exhaust - but I really don't know their exact functions.
Attached Thumbnails Granatelli Turbo Install-dscn6656.jpg   Granatelli Turbo Install-dscn6659.jpg
Old Nov 8, 2007 | 06:04 PM
  #90
turbo05gt's Avatar
The waste gate controls your boost level by "venting" once you reach your spring level and your BOV expels excess boost once you let off the throttle so you avoid compressor surge.
Old Nov 8, 2007 | 06:24 PM
  #91
89Trooper's Avatar
So the BOV opens at full vacuum (off the gas) to expel excess boost coming back from the throttle body, and closes as vacuum decreases (on the gas more and more) to send all the boost to the throttle body?
And the waste gate has a spring set to open when a pre-determined psi is reached?
Old Nov 8, 2007 | 06:51 PM
  #92
turbo05gt's Avatar
Yep, and the BOV is either open or closed
Old Nov 8, 2007 | 06:53 PM
  #93
turbo05gt's Avatar
you're going to love the BOV sound and find yourself going into boost all the time just to hear it!!
Old Nov 8, 2007 | 07:14 PM
  #94
89Trooper's Avatar
That makes sense... it's like a switch (and not variable).
That's another thing I wondered about - what makes the "turbo" sound. So it's the BOV and not the wastegate?
I always thought it was the wastegate!
Old Nov 9, 2007 | 12:27 AM
  #95
kh765's Avatar
Yup, definitely the BOV. Learned all about turbos with my love for Supras.
Old Nov 9, 2007 | 01:50 PM
  #96
Granatelli's Avatar
Former Vendor
The spring in the waistgate fight the exhuast pressure. The exhuast back pressure reaches the limit of the spring in the waistegate it pushes open. What this does is relieve the amount of Exhuast pressure that can spin the exhaust turbine. The exh turbine is connected to the air inlet side of the turbo (also called the cold side) the the exhaust spins the exh turbine blade, on the same shaft as the air intake turbine blade it sucks air into the turbo and compresses it into the engine. The waistegate is the balance between intake pressure and exh pressure.
The BOV - or blow off valve is exactly what has been stated. I pressure relief to expell excess air pressure build up when the t-body slams shut and the turbo has no place to push the sir it was just producing. You will find our kit does not make a ton of turbo noise as we size the BOV to move a ton of air on decell.
Old Nov 9, 2007 | 02:27 PM
  #97
turbo05gt's Avatar
What wastegate and BOV do you use in your kit?
Old Nov 9, 2007 | 04:36 PM
  #98
89Trooper's Avatar
I hope it makes at least some noise!
Old Nov 9, 2007 | 05:01 PM
  #99
89Trooper's Avatar
wastegate = Tial
blow off valve = HKS
Old Nov 9, 2007 | 05:07 PM
  #100
turbo05gt's Avatar
nice, quality stuff
