Gear install question
Old 1/14/11, 08:49 AM
Dread53's Avatar
Something no one has mentioned regarding side shims - they need to be one piece! The kits I've seen come with stackable shims, although I have seen some that use a housing to contain the stacks. If you don't use a solid shim they can work out from under the bearing retainer and destroy your gears. The idea behind the stacks is to figure out what thickness you need and then order the correct single piece. Tooth pattern always needs to be checked before sending it down the road.
The new bearings are more of a CYA thing. The pinion bearing absolutely requires a press and bearing puller for removal to get to the shim and the side bearings don't have to come off. I've done literally hundreds of gear changes and they can be a challenge. A lot of those have also been re-dos of other shops work.
There are shim kits available that no longer use a crush sleeve, and I've only done that once. If you do use the sleeve, be very careful when tightening it. It takes LOTS of torgue to tighten and is junk if you go too far.
Old 1/14/11, 01:35 PM
5pointoh's Avatar
I have ordered the basic install kit made by Ford Racing. I am assuming that will have everything I need for this install.
I will run it by the mechanic who is going to be doing my install.
Old 1/14/11, 06:45 PM
lxlaw's Avatar
wow, hate to tell ya, i told ya. You are fine with ford racing gears. dont be over paranoid about it.
Old 1/15/11, 12:34 AM
5pointoh's Avatar
Not paranoid at all.....though I would be if I were doing the install myself , therefore I am definitely having an experienced shop do it I will follow their suggestions to use the basic kit....and definitely FRPP gears. Motive and Richmond gears are either the same price and on some sites are even more expensive. Cant figure that one out.
Old 1/15/11, 05:28 PM
lxlaw's Avatar
FRPP gears 99% of the time do not require reshimming. Richmond and other aftermarkets, will have to be reshimmed.
Old 1/16/11, 12:16 PM
5pointoh's Avatar
FRPP gears all the way!
Old 1/16/11, 07:29 PM
Everett's Avatar
Doesn't motive make ford gears.... Some of them I am pretty sure
Old 1/16/11, 09:32 PM
5pointoh's Avatar
On the CJ Pony Parts website, they indicate that one of their gear sets is made for Ford by Motive. The rest of them are genuine FRPP gears.
Old 1/22/11, 01:37 AM
5pointoh's Avatar
Just ordered my FRPP 410 gears from CJ Pony! Cant wait to feel that gut wrenching acceleration
Old 3/11/11, 09:09 PM
tdbrown75's Avatar
You get them in yet 5oh? I like them so much I'm on my 4th set!
Tim
Old 3/12/11, 08:53 AM
06SatinSilver's Avatar
i just had my gears done ...28k on the car...i had a buddy that has done many many ford gear swaps and he has had issues with the s197s he has done...something is just a little different that makes them real touchy when doing the pinion preload and shimming...its more sensative for some reason...he trusted the calculations on the pinion shimming and had to re do the job cuz i had a coast side whine...went with his gut the second time and it came out good...we used new bearings...we did have a clutch pak issue though with them making noises on low speed turns...i think it was due to using the lucas full syn oil additive instead of frict mod...i drained a little and put some trans x additive in it and it cut it almost out...gonna drain it soon and replace it with amsoil 75/140 and some ford additive...that should kill it all... MAKE SURE YOU GET THE FORD GEARS WITH THE "N" IN THE P/N...THE "M" GEARS ARE THE OLDER ONES THAT WERE MORE PRONE TO NOISE....
Old 3/12/11, 10:59 PM
5pointoh's Avatar
Tim
Will be putting them in when the car comes out in the summer
Old 3/12/11, 11:00 PM
5pointoh's Avatar
Originally Posted by 06SatinSilver
kill it all MAKE SURE YOU GET THE FORD GEARS WITH THE "N" IN THE P/N...THE "M" GEARS ARE THE OLDER ONES THAT WERE MORE PRONE TO NOISE....
Anyone else have problems with these older gears with the "M" in the part number?
Jim74656
5/1/23 02:15 AM
ssjbuu
8/28/15 08:55 AM
trackpack13gt
8/8/15 11:23 AM
Bullitt 3309
8/2/15 10:20 PM
Quick Reply: Gear install question
