Which Ford strut mount do I want?
Ok;
I'm almost ready to get my shocks and struts installed. All I need to do is to get replacement strut mounts. Since I don't plan on doing any track racing, I'm going to go with the Ford factory replacements. The problem is that they're three different ones listed.
A) 7R3Z-18183-A is an upgraded part.
B) M-18183-A is listed as a replacement part
C) GT500 (I don't know what the part# is.
So which ones do I want to order?
Walt
Walt
I went through 3 sets of the OEM replacements after struts and springs, finally bit the bullet and paid $300 for the Steeda's, not a single problem since. They have lots of adjustment tolerance too, so you can get the alignment done properly. In my book, worth the $.
Administrator, Shop Manual PDF Poster, Parts Locator & Spam Bot Eliminator!!
Received 2,861 Likes
Ok;
A is The GT-500 Mount I Recommend These
b is the Ford Racing Part Number and Are Identical to A
These are 30% Stronger than the Non Gt-500 Mounts
KC
Walt
KC
Walt
I'm trying to make practicle decisions without compromising either project. The Ford pieces will suit my driving style while getting the job done the right way.
According to the TSB for front end noise over bumps, the part number for the revised upper strut mount is 8R3Z-18183-B. That is the part I will be ordering as my J&M camber plates make too much noise, even though said noise is considered normal for a part with a spherical bearing.
Jon
Jon
Jon
Jon
KC
I would go with Steeda, otherwise, when the new set you purchase goes bad, by the time you have to get a second set, you'll be close to the cost of the Steeda one. Find a Authorized Steeda parts dealer, they can get it a little cheaper (I paid $230 for mine, 'cause they didn't care to make money off of it, I was getting other work done with the shop). JMO.
7/30/15 06:47 AM
