Which Ford strut mount do I want?
Ok;
I'm almost ready to get my shocks and struts installed. All I need to do is to get replacement strut mounts. Since I don't plan on doing any track racing, I'm going to go with the Ford factory replacements. The problem is that they're three different ones listed. A) 7R3Z-18183-A is an upgraded part. B) M-18183-A is listed as a replacement part C) GT500 (I don't know what the part# is. So which ones do I want to order? Thanks Walt |
The first part number is correct. The second one is a Motorcraft part and the GT500 ones clunk like the original ones did.
I went through 3 sets of the OEM replacements after struts and springs, finally bit the bullet and paid $300 for the Steeda's, not a single problem since. They have lots of adjustment tolerance too, so you can get the alignment done properly. In my book, worth the $.
Originally Posted by WaltM
(Post 5621091)
Ok;
I'm almost ready to get my shocks and struts installed. All I need to do is to get replacement strut mounts. Since I don't plan on doing any track racing, I'm going to go with the Ford factory replacements. The problem is that they're three different ones listed. A) 7R3Z-18183-A is an upgraded part. B) M-18183-A is listed as a replacement part C) GT500 (I don't know what the part# is. So which ones do I want to order? Thanks A is The GT-500 Mount I Recommend These b is the Ford Racing Part Number and Are Identical to A These are 30% Stronger than the Non Gt-500 Mounts KC Walt |
So they're all the same? I heard that the GT500 isn't a perfect fit (the studs are too tall). Will they fit ok?
Originally Posted by azoufan
(Post 5621176)
I'm trying to make practicle decisions without compromising either project. The Ford pieces will suit my driving style while getting the job done the right way. |
Which struts and springs are you going with?
Originally Posted by Glenn
(Post 5621531)
(Post 5621284)
KC |
I would go with Steeda's. I'm going to replace my stock ones with them.
The Steeda's are worth every penny. No clunk or pop and you have the camber adjustment w/o having to get plates.
1 Attachment(s)
According to the TSB for front end noise over bumps, the part number for the revised upper strut mount is 8R3Z-18183-B. That is the part I will be ordering as my J&M camber plates make too much noise, even though said noise is considered normal for a part with a spherical bearing.
Jon |
Originally Posted by Jon_Purdy
(Post 5623997)
Jon KC |
I would go with Steeda, otherwise, when the new set you purchase goes bad, by the time you have to get a second set, you'll be close to the cost of the Steeda one. Find a Authorized Steeda parts dealer, they can get it a little cheaper (I paid $230 for mine, 'cause they didn't care to make money off of it, I was getting other work done with the shop). JMO.
Is there a way to tell if you have the newer upgraded ones? I have an mid to early 07.
Reviving this thread cause I'm looking for a good source to order the upgraded Ford mounts...
anyone? |
Originally Posted by rony1976
(Post 5626698)
