Filter Clean/Replace?
Old Sep 5, 2007 | 11:16 AM
Arrow's Avatar
My CAI has a washable hi-flow cone filter. How often do you think should I clean it? Is it better to just replace it?
Um...also how do you clean it? I know it says "washable" but I doubt they mean to take it into the shower with me.
Old Sep 5, 2007 | 12:00 PM
fastmover05's Avatar
Id be interested in this to! I would assume you take it to the sink and run some water over it?
Old Sep 5, 2007 | 12:07 PM
Arrow's Avatar
Well, a friend and coworker said I should pick up a K&N filter cleaner kit, which has some kind of spray cleaner and oil. Supposedly you spray the filter outside with cleaner, then wash it with water, let it dry, then spray it with the oil on the outside.
Hell, for all that work, might as well just buy a new filter.
Old Sep 5, 2007 | 12:29 PM
might not be as cheap but may be easier
Old Sep 5, 2007 | 02:58 PM
Rob O's Avatar
I don't have a CAI on mine but I've seen other threads about the oil coming off the filter & coating the MAF sensor--is this a problem normally & is there a way to clean the sensor without a lot of trouble?
Old Sep 5, 2007 | 03:08 PM
zipperhead's Avatar
I purchased a clean and recharge kit for my Green Filter for $16. It woke my car up although the Demolet cold air kit I purchased suggested to clean every 25K miles. Must be I was ready for a clean and recharge
RECHARGE OIL & CLNR KIT 2000
from airfiltersonline.com
Old Sep 5, 2007 | 03:16 PM
itsmetoo's Avatar
I clean mine using the K&N filter kit. It is really easy...spray cleaner on it....hose it off...let dry in the sun...spray oil on it...put it back on the car. I usually do it on an afternoon that I don't plan on driving it until the next day.
I would rather do this than spend $40 or $50 on a new one. Of course you could always buy a spare one and rotate them. Always have a clean one on hand.
The MAF is easy to clean as well. Only a plug and 2 screws hold it on. Just spray MAF cleaner on the wires...let dry and put it back on.
Old Sep 5, 2007 | 03:17 PM
Stormbringer's Avatar
Mine actually says "do not oil" on it.
Old Sep 5, 2007 | 06:51 PM
Arrow's Avatar
Yeah, I was looking at mine tonight. Same thing. Says something like "do not wash with oil."
I like the idea of having two. Maybe I'll do that and always have a swap. That way when I clean one, I can just pop in the other right away. Since it's my only car, it kinda sucks taking it out of action for hours on end.
Of course...it's out of action right now. Something's fudged with the MAF.
Old Sep 5, 2007 | 06:58 PM
Rob O's Avatar
Sounds good to me--when I had my Pontiac I used one for several years but with changes in electronics in cars I'm concerned about screwing up that MAF. I'll shop around & probably get 2 & switch them out.
NC14GT
Feb 20, 2023 09:42 AM
MustangConvert11
Sep 30, 2015 08:01 PM
southern stang
Sep 26, 2015 04:19 PM
TripleBlack14
Sep 17, 2015 07:48 AM
