Exhaust sound clips
Exhaust sound clips
I went to the sticky for this stuff, but for some reason none of the links worked. Do any of you have sound/video clips of the exhaust mods you have done?
Thanks.
Thanks.
With the prochamber the two sides of the exhaust are connected with a boxy chamber instead of piping. The result is a great sound! It is more expensive but well worth it.
Location: New Carlisle, Ohio (20 miles north of Dayton)
Here is my offroad MacProchamber with GTA mufflers on Brenspeeds dyno in May. I tried a bunch of different combos. This is my favorite.
Scott
http://s138.photobucket.com/albums/q...rent=Dyno2.flv
Scott
1 Post
Scott
Scott
![Lol](https://themustangsource.com/forums/images/smilies/lol.gif)
![Biggrinjester](https://themustangsource.com/forums/images/smilies/biggrinjester.gif)
I'd like to hear more of the GTAs/Prochamber at idle.
Is it still easily bearable on a daily driver? It sounds like it would be pretty smooth.
What is involved with the install of the prochamber?
Loses the cats?
O2 sensors?
Does it need a tune?
Require cutting or just bolt up?
Loses the cats?
O2 sensors?
Loses the cats?
O2 sensors?
Loses the cats?
O2 sensors?
The Mac Prochamber with the GTA's is the best for a daily driver. I used to run Borla's and the drone killed me. My present setup is loud when I want it to be loud. At cruising speeds it has "NO DRONE" at all. But depress your right foot a tad and she will get quite aggressive. I am running the offroad version which requires you to remove your stock H-pipe and cats and the Prochamber is a direct replacement. Your O2 sensors are attached to the offroad legs of the Prochamber. You will need your tune changed to make sure the rear O2 sensors are "OFF". Or you can get the direct fit Prochamber which involves cutting your stock "H" pipe but you retain the stock cats. I ran my car this way for a while and it was not aggressive enough for me so I went with the offroad version and it is just right.
Scott
Randy,
As promised here is my car at idle with offroad Prochamber and GTA mufflers
Scott
http://s138.photobucket.com/albums/q...GTAsatidle.flv
Scott
![Drool](https://themustangsource.com/forums/images/smilies/drool.gif)
Cool. Thanks. I think I'll go with the GTAs and later if I add a tune, I'll put in the prochamber.
Randy,
Scott
Scott
I'm going with ARH LT's and O/R H with new cams and heads over winter... I can't wait.
Let us know what kind of power you make with the cams. Which cams are you going with? I also noticed you are going with a KB. You are going to get a grind that will work with the S/C, right?
The blower will have to wait till the next year unless I hit the lottery or we have another huge manhunt and I end up working another 650 hours of OT in 1 year. I will definately go with the grind that is geared towards a blower and suffer though it for the year that I am still NA with a blower grind.
9/10/15 12:44 PM
robjh22
9/8/15 12:31 PM
