eibach kit cheapest and best way to go
Old May 19, 2008 | 06:02 PM
muslenutz's Avatar
My buddy told me just to buy a street spring kit and a camber kit. Should this be good enough for just some around town driving without jeopardizing to much?
Old May 19, 2008 | 06:10 PM
how much do you want to drop it or do you want better handling while keeping the same ride height?
Old May 19, 2008 | 06:42 PM
muslenutz's Avatar
I'm fine with the stock handling. I just don't want to make it worst then what the stock comes. I'm looking to drop 1.5 all around. With it not effecting to much performance or cash. I also don't want any regrets.
Old May 19, 2008 | 07:57 PM
Deric's Avatar
http://www.latemodelrestoration.com/...0%201&comp=LRS
Old May 19, 2008 | 08:08 PM
slipnotovk's Avatar
steeda ultralites FTW!
just installed a set myself a few weeks ago and i couldnt be happier. about a 1" drop in the front about about 1.5" in the rear. ordered from brenspeed along with a hurst short throw comp plus shifter and received it all in less than a week.
Old May 19, 2008 | 08:39 PM
2005mach1's Avatar
I drove to Hewitt Tx on Sat and picked up an set of FRPP M5300K along with the GT500 upper spring mounts. man it rides good. I do think you need a set of camber bolts.
Originally Posted by Deric
Attached Thumbnails eibach kit cheapest and best way to go-car-springs-007.jpg
Old May 20, 2008 | 12:28 AM
SONICBOOST's Avatar
I have the eibach pros and have been happy with them. The drop is perfect...Just the springs can make the ride a little rough. Might want to consider shocks/struts and lca's if that doesn't come in the camber kit...
Old May 20, 2008 | 09:35 AM
adrenalin's Avatar
I had done just that and found the ride to "harsh" to I removed the springs. I won't do it again until I can get some D-Specs, LCA's and adjustable Panhard rod.
Old May 20, 2008 | 02:03 PM
MaverickMLFD371's Avatar
the eibach springs are fine. however, with stock struts, the car is going to ride rough and bouncy.
its best that when you change your springs, you change the struts as well. you can find a good set of non adjustable struts (Steeda ProAction, Tokico HP Blues) for a good price.
you will also need to buy other parts to compensate for your drop.
new strut mounts are needed. since you are just looking for more driving handling, you can re-order the Ford Factory Strut Mounts. you can't re-use the ones on your car right now, they are a 1 time use only.
you will need to buy a panhard bar to re-align your center axle when you drop your vehicle
and you will also need LCAs & relocation brackets, for your car will have terrible wheel hop.
Old May 20, 2008 | 05:54 PM
muslenutz's Avatar
Tell me what parts i need so I can add it all up please.
Old May 20, 2008 | 06:45 PM
GrnT's Avatar
I pick up my Upper spring mounts tomorrow.
I picked up a set of TEIN S-Tech's for 144 shipped from K2motor. I have not recieved them as of yet. I have to find a set of camber bolts to. Springs, Upper spring mounts(M-18183-A), Camber Bolts. Panhard bar later.
MeK2motor
Old May 22, 2008 | 03:32 PM
get Eibach Camber bolts $25
and get the Ford Strut Mounts from any ford dealer
Road_Runner
Sep 2, 2024 04:46 PM
09-gt/cs
Oct 15, 2015 10:03 AM
GeoWett
Sep 30, 2015 06:40 AM
AJ_Trevino15
Sep 28, 2015 07:51 AM
MustangGTCS13
Sep 17, 2015 07:38 AM
