driveshaft vs. headers
Old Sep 28, 2007 | 09:16 AM
YaoNYC's Avatar
hi all,
which upgrade would u do first? which one will provide more performance?
assume i already have CAI/tune/axle back GTA's
thanks!
Old Sep 28, 2007 | 01:29 PM
spyder7724's Avatar
Originally Posted by YaoNYC
hi all,
thanks!
Spydershaft !
Old Sep 28, 2007 | 02:01 PM
R-code's Avatar
Driveshaft for sure. Less headache and it's easily reversible if a warranty issue arises.
~Mike~
Old Sep 28, 2007 | 11:00 PM
YaoNYC's Avatar
Originally Posted by spyder7724
Spydershaft !
hi spyder. great suggestion!
i see your car is automatic. so is mine.
i guess no issues so far.
do i need to adjust pinion angle with adjustable UCA?
thanks!
Old Sep 28, 2007 | 11:03 PM
YaoNYC's Avatar
~Mike~
thanks mike! great suggestion!
Old Sep 29, 2007 | 01:54 PM
spyder7724's Avatar
thanks!
not usually but there are a few cars out thereat stock height that do need adjusting for whatever reason but it's almost always cars that are lowered 1.5" or more.
Old Sep 29, 2007 | 02:54 PM
RadBOSS's Avatar
Check the angle, then decide.
thanks!
Old Sep 29, 2007 | 03:53 PM
YaoNYC's Avatar
thanks spyder.
my car is lowered with Eibach pro springs. i dont think its 1.5".
its about 1.25-1.3"
YaoNYC's Avatar
thanks radboss...
only if i knew how! haha
Old Sep 29, 2007 | 04:17 PM
RadBOSS's Avatar
Got to Sears and you can get a magnetic base angle measuring tool.
You need to check with the wheels fully loaded ... so that means a car rack that the car rolls on unless you have a buddy at one of those quick change oil shops.
thanks radboss...
Old Sep 29, 2007 | 05:18 PM
GRAYPNY's Avatar
Installing the driveshaft is much easlier then doing headers but they are both very good mods.
Old Sep 29, 2007 | 06:33 PM
I would like to think the headers would give a few more hp than a drive shaft freeing up around 6hp. But seeing your car is lowered I would worry about them hitting the ground. How much closer to the ground do headers sit than the stock exhaust. Cost of headers is double what the drive shaft will cost you.
Old Sep 29, 2007 | 06:43 PM
GRAYPNY's Avatar
Not if you go with shorty headers!
Attached Thumbnails driveshaft vs. headers-jba-shorty.jpg   driveshaft vs. headers-collector.jpg
Old Sep 30, 2007 | 10:09 AM
scramblr's Avatar
Well, the question was posed as which would we do first, implying he's going to do both of them eventually. If it was me (and it was at one point), I'd do headers first. Just for the simple fact that I like to feel the kick in the pants of the mods. Then I'd do the Spyder DS, which is felt quite a bit as well. Of course, if funds are a factor and a mod must be done at this time (wait, that's all the time) then go with the Spyder DS. You'll love both mods!!!
Old Sep 30, 2007 | 10:57 AM
RedFire281's Avatar
Legacy Supercharged Tms Member
In order to adjust the pinion angle you'll need an adjustable UCA or LCA so figure on doing suspension mods before the headers. You should do it anyway if you get wheel hop with the freed up hp and less inertial force from the driveshaft.
Old Sep 30, 2007 | 11:32 AM
spyder7724's Avatar
i wouldn't worry about the pinion angle until it's installed and you see if it needs to be adjusted. most don't need it.
Old Sep 30, 2007 | 04:52 PM
he's already lowered so I would think the pinion angle is off already. Unless he has the adj uca. How far off would the pinion be with the car being lowered 1.4 or so?
Old Sep 30, 2007 | 06:09 PM
YaoNYC's Avatar
yes, my car is lowered Eibach pro springs. i think its about 1.25-1.3" lower.
i have relocation brackets/LCAs ready to install but i did not get adjustable UCAs yet.
Old Sep 30, 2007 | 06:31 PM
spyder7724's Avatar
the relocation brackets should reset it back to stock which varies from car to car but is usually around 0 to +1
i would still install it as is and just see how everything works cause you may not need the adjustable upper but it is nice to have for performance reasons. the rear housing rotates so much with the stock UCA cause the bushings are so spongy. if you do all of it at once you will notice a big change in the feel of the car since you are removing a bunch of the soft spongy stuff ford put there for ride quality and noise reduction. to me it's not bad and i feel more in touch with what the suspension is doing than before. my car just didn't feel like a mustang until i got rid of all the hydro bushings and crap. now it feels like a mustang
Old Oct 1, 2007 | 06:30 AM
MaverickMLFD371's Avatar
hey spyder,
with non adjustable LCAs and a non adjustable UCA, should I be concerned with installing a spydershaft with stock height??
wallace
Mar 29, 2016 10:09 AM
Antigini-GT/CS
Oct 5, 2015 09:43 AM
FromZto5
Sep 30, 2015 05:28 AM
billy y
Sep 24, 2015 11:48 AM
TripleBlack14
Sep 17, 2015 07:48 AM
