Bumpsteer Kit
Old Apr 20, 2007 | 10:31 PM
max2000jp's Avatar
Bumpsteer Kit
Has anyone installed a bumpsteer kit on their S197? I've got a Steed kit laying out in my garage and was going to install it soon. I am just looking for pointers or tips for the install.
Old Apr 21, 2007 | 06:40 AM
R3troGT's Avatar
I just had the Steeda Bump Steer Kit installed this week. Yesterday I had the alignment done, which is a must, so it was my first time driving with the kit. My first impression right now is that the steering feels loser on teh Highway. I will have to drive is some more to see if I like it.
Old Apr 21, 2007 | 08:29 AM
max2000jp's Avatar
Let me know your thoughts with a few more mile.
Old Apr 21, 2007 | 09:05 PM
RadBOSS's Avatar
Its hard to tell the benifit of the kit unless you actualyl measure the bump steer before and after you install the kit, else you won't have any way to know how much or where it was improved.
Old Jul 30, 2007 | 11:38 PM
YaoNYC's Avatar
what does it do?
hi guys,
i lowered car with eiback pro and there are LOTS of bumps in NYC.
is a bumpsteer kit imperative?
thanks!
Old Jul 31, 2007 | 09:00 AM
blkstang06's Avatar
Originally Posted by YaoNYC
hi guys,
thanks!
You might want to check into the Steeda X-5 ball joint. They don't give quit the adjustably a bumpsteer kit gives but their a far superior ball joint compared to the factory ball joint .
Old Jul 31, 2007 | 09:23 AM
kevinb120's Avatar
wow is the spell checker broken today
I never noticed a bumpsteer issue with the S197 Sounds like extra parts for no particular reason. It was an issue with the SN95's but it has nothing to do with the current car. I can see new ball joints for cars as low as ones with Eibach springs for 'perfect' geometry(and the punishing the Eibach's deal out to the car), but the new car just doesn't get that out of shape when lowered.
Old Jul 31, 2007 | 11:52 AM
blkstang06's Avatar
Well! Mr. Grammar I thought this was a tech forum, not a composition forum.... I've got a 1.3 inch drop on the front of my Stag, I have no bumpsteer issues myself....but from the few hundred posts on this issue some feel they do. Have you actually seen the factory ball joint, as in have you personally had the front end of your car apart. The steeda X-5 is is a far Superior unit compared to the factory ball joint. this option would give one the opportunity to gain some adjust ability and up grade to a better component at the same time for about the same cost of a bumpsteer kit..Heres a photo of the steeda X-5 ball joint, race qaulity!........
Old Jul 31, 2007 | 02:52 PM
kevinb120's Avatar
yes yes and yes. Funny enough you just posted agreeing to exactly what I said
If you are using a very low spring like the Eibach, they will beat the tar out of the stock ball joint, and the geometry starts getting off, especially with the rear LCA's. I passed on going over a 1" drop because you should change at least 10 parts going lower when the Ultralites are perfectly fine with all the stock parts.
Old Jul 31, 2007 | 04:45 PM
blkstang06's Avatar
.. Glad to see your original statement clarified ......
Old Jul 31, 2007 | 05:30 PM
kevinb120's Avatar
I just did the stylin' basics because I haven't determined what type of power adder I'm going with later before picking things like gears/suspension so its designed around its motor and how it applies power. Even when I eventually convert to coil-overs and more hard core bits, I'm probably staying at roughly the same height as now. I figured I would address traction and braking issues as they present themselves as the mods add up, rather then building up a N/A car, then turning it into a FI car and having to change half the stuff.
Old Aug 1, 2007 | 06:52 AM
blkstang06's Avatar
I cant blame you Kevin ! If your planning to keep your Stang awhile I think coil-over is the way to go !.........
Old Aug 2, 2007 | 06:50 AM
I am kinda new here but this is one of the first threads I have seen about lowered cars and the bump steer kit. I have not seen any mention of the crappy stock ball joints with lowered cars either. Most say with the eibach kit you really don't need any thing else but then go on to say get the panhard rod and some better shocks and struts.
What does the bump steer kit actually do? I assume they let things travel a little eaiser?
Old Aug 2, 2007 | 07:02 AM
blkstang06's Avatar
Glenn I'm running Ground force performance springs they have about the same drop as the Eibachs. I personally have had no bumpsteer issues either but my thought where if one was, the x-5 ball joint could be a option it has some ajustibilty and is a race quality ball joint ! Kinda like killing two birds with one stone! alleviate some bumpsteer and up grade ball joints at the same time.
Road_Runner
Sep 2, 2024 04:46 PM
09-gt/cs
Oct 15, 2015 10:03 AM
GeoWett
Sep 30, 2015 06:40 AM
MustangGTCS13
Sep 17, 2015 07:38 AM
Sep 16, 2015 06:44 PM
