Big Brake Kits and 18” Fanblade Wheels
Old 5/3/07, 08:39 AM
Authorized Advertiser
StillenMustang07's Avatar
FYI…we checked our AP4400 4-piston kit against the factory 18” Fanblade wheels on a 2007 and they fit! It was close so due to manufacturing tolerances we will probably recommend a 3mm spacer (less than an 1/8”). I have not had a chance to check the factory 18” Bullit wheel, but if anyone has the time to download a template and check their wheel I would greatly appreciate it.
The reason I bring this up is we are having a special on this kit. The front brake kit, rear rotors and hawk rear pads for $1899.00. Check the link below.
http://www.stillen.com/PressReleases...lsMay2007.html
Like I said if someone with the factory 18” Bullits would be willing to check the template or drop by the shop and we can check it, I would really appreciate it.
Thanks All
Old 5/3/07, 10:00 AM
Louie's Avatar
I'm also curious if the 18x8.5" Bullitts fit over those calipers. Anybody?
Old 5/3/07, 10:15 AM
That I think is the big question. I hope that we can verify this soon.
Old 5/3/07, 11:30 AM
Louie's Avatar
Apparently it has already been tried with the 14" GT500 Brembo brakes by a TMS member from the UK (Stig) on his GT/CS. Click on the link in his first post here:
http://forums.bradbarnett.net/showthread.php?t=64727
Here's the relevant info from his website:
One issue with this system is that the factory 18 inch Bullitt wheels have insufficient backspace for the monster Brembo calipers. I knew of this before I started and was faced with the choice of replacing all the wheels (and indeed, I have a set of GT500 wheels ready to go, but that meant 4 new tyres and pressure sensors etc. - that and I prefer the style of the Bullitts!) or using spacers. Now, some people are uncomfortable with using wheel spacers, but providing they are of good quality, hub centric and securely attached, there's no problem. The set I bought was from Driftworks in the USA. They are 1 inch (25mm) spacers which use the original hub studs to attach to the hub, then a new set of studs to attach the wheel. The wheel spacers I bought were a perfect fit, really snug on the hubs (they are hub centric, so they centre correctly on the original hub) and indeed, had to be snugged up with the mounting nuts. To be safe, I used blue locktite on them too as I have little intention of removing them again. The only issue is that the original hub studs are about 5mm too long to fit into the pockets in the back of the Bullitts. The solution? Well, out with the hacksaw/angle grinder and carefully take 5mm off each stud. The wheel then fits perfectly but man, it's CLOSE! Close to the extent that you may need to remove/replace/move the wheel balance weights as they may rub on the calipers. Cue lots of filing of mine (and the factory Bullitts seem to have LOADS of weights on them) until the wheels rotated with no interference.
I wonder if the AP calipers are any smaller than the Brembo ones.
Old 5/3/07, 11:39 AM
I know the Brembos will not work without a large H&R spacer. The AP Racing CP6600 calipers that are used in our kit are not as chunky.
Old 5/3/07, 12:31 PM
MaverickMLFD371's Avatar
my baer brakes I just had installed, I needed a 1 inch spacer on the fronts with my 18" STOCK Bullits!
http://forums.bradbarnett.net/showthread.php?t=64740
Old 5/3/07, 02:21 PM
I can understand the need for the spacer because Baer uses the 2-piston PBR caliper off the 99-04 Cobra. This is a very wide/tall caliper. I also suspect that the contour on the back of the Bullit wheel may be different from the Fanblade wheel.
Old 5/3/07, 07:44 PM
kevinb120's Avatar
If you just do the 14" Baer kit with the stock calipers and two piece rotors, I would think those would still clear???
that stillen kit is a great buy for only $1899 with everything though..
Old 5/3/07, 08:19 PM
RedDragon777's Avatar
I knew the fanblades would work, that is why i love them, to me they have more area for big brakes unlike the bullits
Old 5/3/07, 08:26 PM
Dougxox's Avatar
What? bigger brakes? These have worked fine since 1970
Old 5/3/07, 10:37 PM
Live on rusty drum brakes!
All kidding aside, this is probably the best deal on brakes for the 05+ Mustang. Call me biased, but AP brakes are truly phenomenal!
On a side note, I will also upgrade the front Ferodo DS2500 pads to Mintex Xtremes for no additional charge.
Thanks All
Old 5/4/07, 10:35 AM
classj's Avatar
Well the difference between the fanblade and bullitt spoke clearance is about 0.5" generally. So I would guess something around 15-18mm would be right.
Old 5/4/07, 07:26 PM
rdw401's Avatar
I would love to know about the fit. Don't have the time this weekend to check it though.
Old 5/7/07, 08:26 AM
Has anyone had a chance to check these on the bullits?
Old 5/7/07, 07:45 PM
Every_Mn's Avatar
To you, personally? Not anyone else? So wait, only your fanblades fit big brake calipers?
DarrenGT
8/21/15 07:07 PM
AMWill
7/20/15 08:40 AM
Quick Reply: Big Brake Kits and 18” Fanblade Wheels
