Quick Q: When bleeding brakes....
Old May 7, 2007 | 08:45 AM
Chaotic Bliss's Avatar
should the cap be on or off the master cylinder?
Old May 7, 2007 | 09:03 AM
Scott's Avatar
I leave the cap on and just check/re-fill the fluid occasionally.
Old May 7, 2007 | 10:38 AM
MooStang05gt's Avatar
Bleeding can be done either way... the only thing about doing it with the cap off... if you depress the brake pedal to quickly the fluid in the master cylinder will squirt all over inside the engine compartment.
Bobby M.
Old May 7, 2007 | 08:31 PM
anthony05gt's Avatar
The cap should be off of the reservoir ONLY when filling the fluid level. Brake fluid absorbs moisture even from the air quick as hell. Moisture is the brake systems worst enemy.
lakersfreak
Jun 13, 2022 12:29 AM
robjh22
Dec 14, 2015 08:41 AM
Antigini-GT/CS
Oct 5, 2015 09:43 AM
Sep 30, 2015 07:02 PM
Sep 23, 2015 03:21 PM
