Been busy last 3 nights, but long list of mods is done
Old Mar 8, 2006 | 09:38 PM
cop on my back's Avatar
Cool
Okay, after many weeks and a long trip down to Arizona from Canada to pick up my parts and buy a boat, I have returned home and tonight finished installing all my mods. Here is a list.
Steeda Tri-ax shifter
BMR LCAs
BMR adjustable panhard rod
Eiback pro series springs
off road H-pipe
Flowmaster axle backs
First, installation on all parts was a breeze. The only hard part was puting in the shifter without taking the driveshaft off. I know others on here have done it, but I was just about to the point where I was about to say it is not possible. I persaveered and I was able to do it.
Exhaust - the Flowmasters are awesome in my books. I only started it up in the garage and reved it up to get the idea of the sound and I was impressed. I didn't drive it until I installed the H-pipe and that is where I am not 100% happy. There is a lot of trumpeting and it is very raspy two different times when excellerating. Not to mention it is pretty bloody loud. I am on the fence as to whether or not I will put the cats back on. There is a noticeable HP increase and that alone will probably make me keep the H-pipe in the long run. I did get a CEL after 2 days.
BMR LCA's - Nice parts, but I think the grease nipples are no good because when you pump them up, the grease comes back out. The little check ball in the end doesn't seem to work. I will get some good quality stainless ones from my work, not a big deal. The wheel hop is about 80% cured. I will look into getting the UCA to hopefully cure it 100%.
Adjustable panhard rod - very easy to install. Same problem with the grease nipples and the one on the drivers side is not accesable once installed. There is a bracket in the way.
Steeda shifter - Nice high quality part. Installation was a PITA without removing the driveshaft, but I am glad I went this way. The shifting is excellent, but it seems the factory shift **** sits a little higher than stock, even when using the lower bolt locations. (I liked the factory low postition)
Eibach Pro Series springs - Easy to install. I just put them in tonight and took the car out for a quick test run. The car stays nice and flat in a hard corner and it is still a nice ride on a normal road. I doesn't bruise your kidneys when you hit a bump.
With the LCAs, panhard rod and the springs, the rear of the car seems rock solid. I can't wait to get to the track to take on the slalom in the next autocross. There is a huge improvement over an already good handling car.
As for the plastic model in the picture....that will come later.
Feel free to ask any questions or comment. Thanks for reading this long post.
Old Mar 8, 2006 | 10:17 PM
Enfynet's Avatar
One, that's an X-pipe, not an H-pipe.. H-pipes are deeper, X's are raspier/louder. And two, you have it facing the wrong way on the floor. [img]style_emoticons/<#EMO_DIR#>/biggrinjester.gif[/img]
Old Mar 9, 2006 | 12:46 PM
I guess I am just used to the old fox body days. The h-pipe was where it was at! I guess I could reverse the image....no wait that would still be backwards?
Old Mar 9, 2006 | 02:40 PM
2L8IWON's Avatar
Looks good man! Did you use a spring compressor?
Old Mar 9, 2006 | 06:03 PM
Thanks, yes you need a spring compressor. I don't think you could do it without one. Where I live you can go to Canadian Tire (automotive/harware store) and they lend you the tool for a max of 3 days for free.
Old Mar 9, 2006 | 09:38 PM
S197 GT's Avatar
3rd Times A Charm
Good for you! I think you should get the O/R H instead of the X and you will get rid of that raspy sound. It will sound deep and hollow!
I can't wait to get some suspension mods! BMR all the way!
Old Mar 9, 2006 | 10:25 PM
I think I may just do that, thanks.
Old Mar 10, 2006 | 07:14 AM
traffic142's Avatar
looking really good. I just dropped a bunch of coin at BMR site. cannot wait to get it.
BTW they were super in helping me out.
Old May 2, 2006 | 03:17 PM
2L8IWON's Avatar
Just got my BMR Springs and Adj Panhard Bar today! Let the fun begin this weekend!! I need a spring compressor I guess.
Old May 2, 2006 | 08:03 PM
Mongoose's Avatar
The problem with you panhard rod and LCRs is not the fitting. There is no gap between the bushings for the grease to go plus on some of them the hole for the grease fitting was not in the center where the bushings meet. I had to remove about .015 off the inside end of one of the bushings so there would be a gap between them. Install a 90 degree fitting in the drivers side of the panhard and you can grease it. I thought everyone was aware of these problems. Guess not! You would think by now BMR would have caught and corrected this. They sent me a new set of bushings that were also too long.
Old May 3, 2006 | 03:29 AM
traffic142's Avatar
I noticed the greasing issue also. I have tried to grease them with the suspension not loaded....it helps. Also on the LCA install, I did plenty of grease before hand on the sides of the bushings.
Old May 3, 2006 | 04:56 AM
05GTSILVER's Avatar
since you lowered the car you now need the lca relocation brackets. the bolt ons are preety to install. i have the the weld ons with bmr ph bar, brace, pro kit, and bmr adj lca's and i have no wheel hop. reloc brackets are the way to go. and yes you do need to change to an off road h and trash the x. i have the magnaflow x with cats and flows, and the sound is great but a tad raspy. i will be going to the pypes off road h soon.
Old May 3, 2006 | 06:02 AM
ren274u's Avatar
darn im sick of my off road x after 3 days, i think im gonna trade it for an h
Old May 3, 2006 | 02:04 PM
Trampus's Avatar
Even if you go with the h-pipe, you're still going to get trumpeting.
Mpaps
Oct 11, 2017 08:06 PM
JTB
Motorsports
Oct 29, 2015 09:07 AM
wannabe
Sep 23, 2015 05:36 AM
robjh22
Sep 8, 2015 12:31 PM
Sep 8, 2015 10:45 AM
