Bassani Axle-Back intsalled....but alignment issue
Installed the Bassani Axle-backs this morning, install was simple. I am loving the sound and it looks great on this car. The only trouble I am having is the right muffler isn't aligning the way it is supposed to. For those of you who have installed new exhaust systems for the '05, you know that the brackets holding up the mufflers have a rubber mounting, which doesnt allow pretty much any room to adjust. I don't know if these you can tell in these pictures, but the right side hangs down lower then the left. The left side lined up perfect but the right side didn't. How can I adjust the right side so it tucks up more into the car and have it lined up like the left side? The metal hook appers to be a little long so that might be why it hangs so low, maybe it is defective and I should try to get a new one? Or should I try to bend it a little? Don't get me wrong, I am loving the Bassanis! I am just **** when it comes to my car, everything has to be perfect.
You may have to bend the hangers a bit. Needed to do some minor physical adjustments on my Borla before it was centered. Maybe when they weld the hangers, sometimes they aren't perfect.
9/24/15 08:15 PM
