Anyone with high altitude dyno numbers?
Old Jun 3, 2005 | 05:13 PM
j-stang's Avatar
Thumbs up
heck all - today I dynoed on a Dynojet for the first. Let's just say I was not impressed at first. Then I spoke with the dyno tech (owner) and he said those are the numbers I should expect to see at our high altitude.
Here's the graph..
[attachmentid=23157][attachmentid=23158]
88 *F 6000FT ELV both pulls
JLT, Predator DTP 91 tune, SLP Loudmouth cat back, M5 tranny
Brent from DTP Tuning was a great help. My first run we figured out I was running 11.6 a/f ratio (because of the altitude) and we then increased it to 12.7 to get the numbers I show above.
I think my spark was around 26 at WOT (hmmm. I forgot).
Old Jun 5, 2005 | 10:26 AM
The Boss Hog's Avatar
Originally posted by j-stang@June 3, 2005, 7:16 PM
... I spoke with the dyno tech (owner) and he said those are the numbers I should expect to see at our high altitude. ..
Jason,
Since nobody else answered you, I though I would give it a go. Raw, uncorrected, actual (pick the name you want) horsepower does decrease significantly with altitude. That's why your car does in fact run slower at high altitude. But, SAE corrected horsepower does NOT vary significantly with altitude. That's the whole reason for using the correction factor. The axis label on your chart says it is SAE horsepower so you should expect that same number if you dyno'ed at sea level.
If you are interested in some reading, here is a website explaining what SAE correction really is.
The Boss Hog
Old Jun 5, 2005 | 05:36 PM
j-stang's Avatar
Hey thanks Boss -
Actually someone did answer my post. For some reason it did not show up on the replys. JeffGT is up in Colorado and he said he experienced the same.
Thanks for the link - I'll check it out.
Cheers_Jay
Old Jun 6, 2005 | 08:37 AM
MrMorden's Avatar
Shouldn't an SAE corrected graph adjust for altitude?
Old Jun 7, 2005 | 09:35 AM
deurges05's Avatar
I am at the same altitude, and planning on buying the JLT CAI with the DTP tune... can you find out exactly what needed to be changed so my engine doesn't explode at this altitude? (The major problem here is that there aren't any really reputable tuners that I could trust)
Old Jun 7, 2005 | 07:13 PM
j-stang's Avatar
Al- The only thing I would watch is your a/f ratio. You need to go to a dyno. Even after I received my tune from DTP I still went to a dyno to check everything out. Which I'm glad I did. WE called Brent at DTP while I was at the dyno and he helped us out. I must say Brent at DTP is awesome. He has been so helpful.
Hoep that helps._Jay
May 3, 2026 05:42 AM
Road_Runner
Sep 2, 2024 04:46 PM
PonyMuscletang13
Sep 29, 2015 09:40 AM
