0-60 time with 4.10 gears
Old Aug 17, 2007 | 07:55 AM
gremlin190's Avatar
I'm interested in getting this mod and am wondering about how much faster your 0-60 times will be after the mod if the stock is ~5.1 sec? Ihave never rode in one and have no idea of the difference.
TIA
Old Aug 17, 2007 | 04:26 PM
DavidM's Avatar
Chad, your 0-60 times will be mostly affected by your ability to find traction after the 410's. With sticky tires you should be able to get into the 4 second zone on mostly stock or mildly modified, manual trans car.
Old Aug 17, 2007 | 06:18 PM
gremlin190's Avatar
Thanks for the answer. So I'm guessing my stock bfg will spin all over the place after changing the gear ratio? Is it on wot or can you let off the clutch slowly and then punch it? I am trying to translate the number of tenth of a second into *fun factor* as I really don't drag with this car and I use it as a daily driver. I'm debating over this compared to a s/c as I don't think there would be much of a concern in blowing my engine with this mod and I may get close to the same performace ???
TIA
Old Aug 17, 2007 | 06:46 PM
05GT-O.C.D.'s Avatar
I lust for a M24
Same performance? No.
But, fun/$ - yeah, go w/ the gears.
Old Aug 17, 2007 | 06:50 PM
gremlin190's Avatar
So am I looking at roughly say 4.8 for gears and say 4.5 for s/c tuned at ~ 400 rwhp ???
Does that sound close approx
Old Aug 17, 2007 | 07:06 PM
don_w's Avatar
I've timed mine at 3.0 seconds flat in the 0-60mph with a SC and 4.10s. And about 0-75mph in 4.5-ish.
I'll go out on a limb here and guess that my KB is responsible for most of the gains.
Old Aug 17, 2007 | 07:10 PM
chrisc9867's Avatar
i am going to assume that is on DRs and not street tires....if that is on street tires i am going to die.
i dont want to die
Old Aug 17, 2007 | 07:13 PM
don_w's Avatar
i dont want to die
My street tires are drag radials... my track tires are slicks. I did the testing at the track, so traction was good and the timing was verifiable (G-meter vs timeslip... less than 0.1 sec variance between the two).
Old Aug 17, 2007 | 07:16 PM
gremlin190's Avatar
That's got to be a RUSH!!!
However, you have a completely modded motor, that's more than I want to put into it.
Now if your saying there is going to be more than 1 second difference with a s/c then you have my curiosity. However, I don't think I would go over 400hp on my stock block. so 0-60 say ~4.0 sec with a s/c or 4.8 w/ gears???
I don't want to spend more than around $5000 more on my car as far as drivetrain
Old Aug 17, 2007 | 07:18 PM
chrisc9867's Avatar
at least i didnt die, very nice times though
Old Aug 17, 2007 | 07:26 PM
DavidM's Avatar
TIA
THe BFG's wont spin all over the place if you practice getting out of the hole. They wont stick as well as Dr's or slicks at the track. I ran for a long time on the stock pirellis and BFG KDWS. They do fine for the street for where I am at N/A. With the stock Pirellis I was able to pilot my car to a 13.55 in the qtr at 103 in completely stock trim. After the gear swap I could only muster a 13.4 because of the increased torque multiplication at the rear tires. In short I was spinning bad. A switch to DR's knocked the 1/4 mile time down by a solid 4 tenths. Again I still run the KDWS on the street daily. Practice is the key to traction. Also I wouldn't focus too much on 0-60. As there is way more to good performance than that.
Tazzie's Avatar
With 3:73's my 0-60 is 4.82.
Old Aug 17, 2007 | 07:53 PM
gremlin190's Avatar
Then maybe 4:10's + tires are worth more than just a few tenth's
As far as 0-60 times. That is just how I can best measure performance being that I never have been to a track
Old Aug 17, 2007 | 08:07 PM
I lust for a M24
I'm just curious. Have you priced gears or a blower?
Not to be smart, but it's like asking if I should buy a Corvette or just stick w/ a Cobalt.
But yeah, as much as I'd like a blower, tires will be my next mod, then gears.
Old Aug 17, 2007 | 08:12 PM
jedikd's Avatar
0-60 times don't tell you much anyways...most would consider the 1/4 mile the true acceleration test
Old Aug 17, 2007 | 08:18 PM
gremlin190's Avatar
gears, less than 1000 and no engine trouble
s/c, over 5000 and possibly cause problems to my engine/ drivetrain
And I didn't find your question smart, I respect most everyone around here and value your opinion.
I'm going to bed now so no more post from me. Thanks for the input
Old Aug 17, 2007 | 08:28 PM
karlmalone1's Avatar
I agree with DavidM about not focusing too much on the 0-60 times. When you get into a higher level of power, 0-60 times are limited by traction mostly and not engine power. A better indication of how much you would be gaining with a supercharger verses gears would be a 0-100 time or a quarter mile trap speed. A supercharger might be only 3 or 4 tenths of a second quicker to 60 than a set of 4.10 gears, but in reality the power would feel much more substantial. Let's say a stock 5 speed with 3.55s hits 60 in 5.1 seconds, 100 in 12.7 seconds, and has a quarter mile trap speed of 103.3 mph. A set of 4.10s might drop that 60 mph time to 4.8 seconds or so, and the 100 mph might decrease to 12.4 let's say, with a trap speed of 104.0 (just guesses here). But it is a totally different ballgame with a supercharger. Where the 60 time might hover around 4.5 seconds, the 0 to 100 time could decrease to around 10.3 seconds or so, a substantial difference, with a trap speed of around 112.3 (or more, im just pulling these figures out of my old hiney)...but you get the picture. If i were you and i had an extra 5,000 dollars that i wouldn't miss, a supercharger would be my first priority. Sorry for the long post, but hope this helps.
Old Aug 17, 2007 | 09:59 PM
karman's Avatar
So what would you say about my g-meter 4.6 and 13.5 with 3.55 and stock 18" Goodrich?
Or my best of 4.43 and 12.90?
(Of course this is with me getting almost no 1st gear spin and 50 degree temps).
FYI Don't talk to me about calibration, it is set right.
Old Aug 18, 2007 | 12:07 AM
bored out's Avatar
Did you calibrate correctly jk Nice times
JMU
Sep 27, 2015 07:53 AM
ssjbuu
Aug 28, 2015 08:55 AM
Feffman
Aug 22, 2015 06:27 AM
trackpack13gt
Aug 8, 2015 11:23 AM
chadh92
Jul 29, 2015 06:56 AM
