Which is Better All Car vs. Car Topics
GT vs Bullitt Comparison
Old Apr 6, 2008 | 09:54 PM
  #101
RCSignals's Avatar
Originally Posted by 2k7gtcs
Martimus and RCSignals, you are incorrect about my posts and comments. Find the post where I have attacked the Bullitt car or said it was inferior. You're picking on the wrong guy here. I have poked fun at some Bullitt owners for their proclivity to argue with all other GT owners, especially GT/CS owners who don't automatically say the Bullitt is better than their own cars. Check the posts and get your facts straight. It is because of posts like the ones above that I have written what I have. I've even said I like the Bullitt, I like George's Bullitt, I like all Mustangs. You however are exclusive and called me a Bling boy, I went along with it in good nature, but now I'm just tired of it.
I never indicated you specifically did I. Martimus with this is kidding with you because of your comments about supposed attacks from Bullitt owners and comments about you should know better than remark in a thread about Bulllitts.
You don't have to look far for those posts from you.
That said the issues and 'attacks' have come from CS/GT owners in general, not from Bullitt owners.
Old Apr 6, 2008 | 09:57 PM
  #102
RCSignals's Avatar
Originally Posted by MrClean
Therefore, the "logic" is the same in both cases, except the Bullitt's "standard" timing map is a little more aggressive than a non-Bullitt GT's standard timing map, and backs off to a secondary timing map accordingly when 87 is burned, due to knock detection. The Bullitt engine also has increased airflow with the CAI, which probably accounts for a portion fo the 15 hp.
The logic is not the same. Most any engine tuned to run on regular will also burn premium without problem. It will not gain any advantage from it though.
Most any engine (even with knock sensors) tuned for Premium will not readily adapt to burning regular fuel without problem.
But you of course are correct
Old Apr 6, 2008 | 10:05 PM
  #103
MrClean's Avatar
No, it is obvious you're correct.
Old Apr 6, 2008 | 11:17 PM
  #104
Martimus's Avatar
I didn't realize your '05 was a V6, and in that case, I was clearly wrong makinfg that statement. It is interesting, however, that you bash the GT/CS and yet the very mods (visual) that make it such are the ones you made to your V6....
As to the 87 octane, I think it is you that needs a little more education on the tuning and mechanical aspects of these cars. The 87 rating for non-Bullit S197 GT's is a minimum rating, as you might discern from the context of the excerpt you quoted from the manual.
Octane detection would amount to a lab under the hood. The most advanced system do date in this respect is the new BMW M3's engine, that uses changes in the ignition systems induction to detect pre-ignition before it happens, but that is not the level of sophistication or complexity found in out Ford engines. The self adjusting timing on the Bullit (and other S197 GT's is a reaction of -preignition.
The fact is that the all the S197 GT's PCM's (Sapnish Oak) have multiple timing maps, and will use the most aggressive map as long as there is no pre-ignition detected, and this I know from talking to the tuners who've tuned my car (using both base SCT files and also the stock software in my car, which came with an unusually aggressive 29º ignition timing from the factory in the "aggressive" map).
So Ford saying that the Bullit's PCM has "octane detection" literally amounts to the PCM running an aggressive timing map as the default, and if knock is detected it backs off the timing, the same as the Spanish Oak has done so far on S197 GT's, except that the aggressive file is a little more aggressive, hence the 15 hp bump.
TMS is a great forum, but if you want to inject more specific technical information into your knowledge-base, I invite you to visit www.S197Forum.com
Yes I did add side louvers (and only side louvers) to my car and found out quickly that I didn't care for the look. Unfortunately with the Ford louvers once you've installed them theres no going back! The little plastic positioner inside the louver requires that a hole be drilled in the side of the car. In order to remove the louvers you've got to replace body panels or find a good welder... both unacceptable solutions to me. As such I was forced to leave the louvers on the car till I sold it.
In reference to the timing mappings I'm not doubting that there are multiple timing maps but its curious why Ford doesn't advertise this fact for any Mustang but the Bullitt. Its also curious why Bamachips and Brenspeed and others write specific tunes for specific octanes and don't seem to readily exploint these multiple timing mappings. Hmm... maybe your tuners know more than Doug and Brent?
Oh and I've provled around S197Forum once or twice.... Heck I've had an account on that forum for nearly a year now! I don't post there cuz I don't find the site all that useful to me. Don_W is a great guy but I can read his exploits over on 2005stang.com. Thanks for the offer anyway!!
Old Apr 7, 2008 | 12:08 AM
  #105
Martimus's Avatar
Ahh... so you're saying that you were ribbing us? So why do you get offended when I rib you right back??? The smilie is a jester...
I do, however, need to get something off my chest. It seems like you're offended that some Bullitt owners don't like the GT/CS. Well I also sometimes find it offensive when GT/CS and Mustang owners in general rag on the Bullitt. Do I not have the right to be offended? I never start this but you can bet yer bloomers that I'll defend this car when I see it being attacked!
In any case I'm sorry that your feelings are hurt 2k7gtcs and I do apologize for my part in it!
Old Apr 7, 2008 | 07:20 AM
  #106
jsaylor's Avatar
Originally Posted by Black GT500
For Your Information:
You do know there aren't really any Bullitt badges besides the faux gas cap on the rear panel right?
On the interior the only Billitt "badge" is the disc on the center of the GT500 steering wheel, oh and the kick plates...
I'm not sure where we disagree here unless your just not referring to the badging inside as, well...badges?
Old Apr 7, 2008 | 07:34 AM
  #107
Martimus,
If it was ribbing than no apology necessary. No hard feelings. Next time I'll learn to judge the ribbing I get better and be more careful about the ribbing I give. Sometimes in type it comes out a little different than intended. I guess I'll have to use more.
But I think you can see that I've never said anything negative about the Bullitt if you check it, and I didn't like being lumped in with some GT/CS, SGT owners who give ya'll such crap about your cars. That's not me.
Gary
Old Apr 7, 2008 | 10:49 AM
  #108
adrenalin's Avatar
Wow, more mustang arguing than I have seen in a while (V6 vs GT rants). Just get in your cars and enjoy them. I don't care if your car has 120 hp or 1,000 hp. If it says Mustang (and is a Mustang) I like it! Now if only I could figure out why GT/CS and Bullitt owners (not all of you) don't realize the car is a GT with some mods. I'll sit here and wait to be flamed.
Old Apr 7, 2008 | 12:28 PM
  #109
Knight's Avatar
Needs to be more Astony
+1!!
Old Apr 7, 2008 | 10:12 PM
  #110
jsaylor's Avatar
Can't we all just get along?
Old Apr 8, 2008 | 10:10 AM
  #111
Rebel73's Avatar
ok, Bullitt Guys and GT/CS guys, LISTEN UP...both our cars start life as Mustang GTs...nothing is added to the Bullitt that can't be added (or removed) to/from the GT/CS. We're just arguing preferences here. I think the Bullitt is cool, just a little "too" understated for my liking.
Old Apr 8, 2008 | 01:12 PM
  #112
Martimus's Avatar
Yo Rob!!!
I don't think anyone is contesting that fact. To be honest that statement can be expanded well beyond just the Bullitt and GT/CS. The Shelby GT, Foose Stallion, Roush, Saleen, and most, but not all, special edition Mustangs have the exact same roots and at one time each moved across the Mustang assembly line before being retrofitted to become a Special Edition.
Whether the Mustang is understated (Bullitt) or over the top (GT/CS) the bottom line is that its still a Mustang! period!
Old Apr 8, 2008 | 01:37 PM
  #113
Amen. Bro!
Old Apr 9, 2008 | 03:51 AM
  #114
future9er24's Avatar
kuuummbaayaaaaaaa.....
Old Apr 9, 2008 | 10:01 PM
  #115
RCSignals's Avatar
Yo Rob!!!
and both you and I have posted that over and over.
Old Apr 9, 2008 | 10:29 PM
  #116
SONICBOOST's Avatar
hmmm
Old Apr 10, 2008 | 08:21 PM
  #117
MrClean's Avatar
I'm feelin' the LOOOVE!!!
Just instelled my Airaid and had a dynotune done at Fastlane....WOOOOHOOOO!
BTE, y'all remember that for all 07+ GT's Steeda has that Adaptive Tuning ($650, including their proprietary CARB certified CAI), which is essentially the same as the Bullit's: monitors several parameters (AFR, knock, etc), and advances the timing until it detecs knock, then backs off a bit.
Old Apr 10, 2008 | 08:36 PM
  #118
RCSignals's Avatar
What's a Bullit?
Old Apr 10, 2008 | 08:40 PM
  #119
RCSignals's Avatar
Mr Clean, is your car Supercharged?
Old May 2, 2008 | 08:56 AM
  #120
gt/cs08's Avatar
Yo Rob!!!
Right on......our cars will always be a Mustang !!!!!!!!
