Mustang Motorsports All forms of racing and motorsports activity allowed!
Track Related Mods
Old 10/16/16, 07:57 PM
  #481
SpectreH's Avatar
Received 1,155 Likes on 843 Posts
I loved the Steeda CAI and tune on my car. It ran great and it would still be installed if I hadn't installed a supercharger.
ofequipmentgolf (10/17/16)
Old 10/17/16, 06:26 PM
  #482
5.M0NSTER's Avatar
Thanks guys, that's what I was expecting to hear. Appreciate the feedback.
TJ, I'll PM you in the next couple weeks. Thanks!
Old 10/18/16, 07:55 AM
  #483
ford20's Avatar
I should have mine sitting in my Garage, just have to check if all the hardware is there. I was going to put it on my car, but the engine decided to eat up the bearings lol.
Old 11/15/16, 08:00 AM
  #484
SGwick's Avatar
Guys, I was thinking of doing a thermostat change (170), coolant w/water wetter to help with cooling (while watching engine temps) since I don't have the money for complete oil/radiator cooler system. Thoughts?
Old 11/15/16, 09:00 AM
  #485
ford20's Avatar
It sucks trying to track a 11-12 car hahaha. I doubt the 170 degree thermostat is really going to help much as most of the people on TMO haven't really recommended it to solve their cooling issues. Plus I believe the computer doesn't even give you full power until the temperature is up to 180 degrees, but I forget the exact temperature. I think you will be better off running the distilled water/ water wetter combo and increased airflow to the radiator than you would be with installing a cooler thermostat.
SGwick (11/15/16)
Old 11/25/16, 10:09 AM
  #486
5.M0NSTER's Avatar
Originally Posted by SGwick
Matt (Steeda) sent me the new tune after I correctly filled out the tune form today and installed it as soon as I got home. Early yet but start up was problem free, no weird (bouncing) idling and back down to 650rpm with no rough movement. Gone is the on/off throttle application, replaced by super smooth, modulated control :-) I still ran it like I always do on the street (under 3.4krpm) but I can sense the power under the surface more readily. The exhaust sound is definitely deeper but only slightly louder (minimal). Exhaust rumble used to be at or above 3K rpm but now occurrence is more frequent (>2.5K rpm) More feedback in a week. So far I'm very pleased with my Steeda purchase and tuning (Matt) :-)
Hey SGwick, I followed your lead and got the same combo taking advantage of Steeda black Friday deals.
If you don't mind sharing, what mistake did you make on your form? I just filled mine out and want to make sure I didn't screw it up also.
Thanks!
Old 11/25/16, 01:19 PM
  #487
SGwick's Avatar
I didn't put that I bought steeda CAI. They thought I just wanted tune
Old 11/25/16, 03:04 PM
  #488
5.M0NSTER's Avatar
Thanks bud, appreciate your honesty. I can't wait to have it all on. I ended up requesting the 91 and 93 tunes. I'll start with 91, but first I need to make sure to have 91 in the tank, lol.
It may have to wait till spring though. It's been fairly warm here so I'm still driving the car, but I think next weekend might be it for the year.
SGwick (11/25/16)
Old 11/26/16, 08:30 PM
  #489
SGwick's Avatar
Just came across this, heard anything about it? Checked forums and the kit was never mentioned (weird)
Attached Thumbnails Track Related Mods-photo507.jpg   Track Related Mods-photo433.jpg   Track Related Mods-photo568.jpg
Old 11/27/16, 08:14 AM
  #490
ElkGroveFordGuy's Avatar
I would think that kit would help a lot!
Ford put a larger radiator and oil cooler on the boss 302 and track pack cars to help this.
Don't forget the boss 302 and track pack cars also have a bigger oil pan and run the 5-50w oil as well.
I would think that the oil cooler and 5-50w oil would help with temps!
SGwick (11/27/16)
Old 11/27/16, 08:48 AM
  #491
5.M0NSTER's Avatar
I'm thinking along the same lines as ElkGrove. I think that's the same kit on my car. I was just staring at it yesterday while changing oil. The filter attaches right to it. And along with lager radiator and thicker oil the cooler does a good job keeping the temps in check.
But for this to work you may need the larger radiator as well. 8QT baffled pan is also a good idea.
SGwick (11/27/16)
Old 11/27/16, 09:43 AM
  #492
SGwick's Avatar
thx guys, I'm working on getting larger radiator
Old 11/28/16, 08:07 PM
  #493
Bert's Avatar
Received 1,547 Likes on 1,060 Posts
I have heard that the Boss oil cooler is not the best set-up, some call it the "oil heater." Not sure if that listing is the original Boss style or an upgrade for the Boss. Since it includes an additional radiator, I think it might be an upgrade because I think the issue with the Boss oil cooler is that it uses the normal radiator.
Check out Mishumoto oil cooling setup.
The 5W-50 oil won't reduce the temps at all, but it will stand up to the high temps better.
Sorry if this was covered earlier in thread, I did not read back through the earlier posts, and I suffer from CRS (Can't Remember ****)
Old 11/28/16, 09:49 PM
  #494
Currently a Corvette Owner!
PJRManagement's Avatar
^ +1 agreed
Boss owners who track their cars call the OEM oil cooler the 'oil heater', as a joke, of course. I believe this is because it is a very small unit that actually runs the engine oil out of the engine, and past an area exposed to anti-freeze/coolant. I've read that this has the opposite affect of what is intended...if you have hot radiator fluid, you'll heat your engine oil instead of cooling it. The images above are for the more traditional set-up, lines running the engine oil out of the engine, but through a radiator-style unit that allows air to pass through it for effective cooling, then back into the engine.
Old 11/30/16, 07:42 AM
  #495
5.M0NSTER's Avatar
Wait, now I'm confused.
The kit pictured above, is it what comes stock on Boss and GT TP cars? Radiator and all?
And the kit above is a liquid to air cooler. So hot oil circulates the radiator and get cooled. How is the radiator fluid involved?
Old 11/30/16, 02:17 PM
  #496
Bert's Avatar
. . . The kit pictured above, is it what comes stock on Boss and GT TP cars? Radiator and all?
I am a bit confused too . . . . the name of the kit "Boss 302 oil cooler kit" is what threw me off.
But I'm pretty sure, NO, that is not what comes stock on the Boss 302. That kit is actually better than the stock Boss stuff, because the stock Boss uses the normal radiator which actually heats the oil in some situations.
That kit includes a separate heat exchanger, which is the way it really should be done.
I guess it must use a lot more oil, to fill those hoses and the heat exchanger?
I hope I got that right because I don't want to add more to the confusion than I already did.
Old 11/30/16, 08:06 PM
  #497
5.M0NSTER's Avatar
Hey Bert, that makes sense. Thanks for clarifying.
Now I'd just like to understand the concept behind the design with no separate radiator. Does the main radiator have a separate path for oil in addition to coolant?
Old 11/30/16, 08:13 PM
  #498
5.M0NSTER's Avatar
I just found the unit which came stock with the Boss and TP cars:
http://www.americanmuscle.com/frpp-b...blue&GID=50319
Now that I think about it I think it brings in coolant from the radiator to cool the passage between the oil filter and thus cool oil. But this wouldn't be nearly as effective as having a separate radiator to circulate oil.
Old 12/1/16, 08:08 AM
  #499
SGwick's Avatar
Sweet! I just scored a used Ford Racing radiator M-8005-MGT (same type used in 302S/FR500S cars) and it just shipped. Just gotta work on that oil cooler kit I posted earlier :-)
Old 12/1/16, 04:51 PM
  #500
5.M0NSTER's Avatar
nice!! That alone will help. Along with a real oil cooler your over temp days will soon be over.
Quick Reply: Track Related Mods
