Mustang Motorsports All forms of racing and motorsports activity allowed!
Track Related Mods
Old 12/1/16, 08:48 PM
  #501
5.M0NSTER's Avatar
I got my Steeda intake/tune combo. I got the 2 main intake pieces together yesterday, but weather is no longer cooperating so it may be in 2017 I get it all installed.
Anyway, that filter and MAF are ridiculous.
SGwick (12/2/16)
Old 12/1/16, 09:55 PM
  #502
ElkGroveFordGuy's Avatar
I just got mine today too!
I bought similar for mine too on Black Friday deals!
I got CAI, tune, trans mount bushing and shifter bracket!
I will be doing a full write up and comparison to my current set up with a
Ford Racing procal tune and K&N drop in filter.
I haven't opened the box yet!
Old 12/2/16, 06:37 PM
  #503
dmichaels's Avatar
Nice stein
Old 12/3/16, 06:07 PM
  #504
5.M0NSTER's Avatar
Hey guys, has anyone here has wheel bearing issues with your Mustang due to track use?
I ask because in March I had my rear axle bearings replaced. Thankfully that was still covered. They were getting noisy.
I just put the car away for the year, but last few weeks I've been hearing low humming from the front, and I suspect front wheel bearings might be on their way out.
Car has ~25k miles and 10 track days. Should I just expect to change out bearings every few years due to track use?
Old 12/3/16, 06:18 PM
  #505
dmichaels's Avatar
I've had zero issues and I'm at around 5k track miles. My friend with a 2011 who has probably 25k track miles killed a rear axle bearing. But I haven't heard much about fronts going from track use. Check TMO
Old 12/3/16, 07:36 PM
  #506
SGwick's Avatar
no issues here, sorry to hear that 5.Monster.
Old 12/6/16, 06:54 PM
  #507
SGwick's Avatar
Wow just got my "used" Ford Racing radiator that I won in an auction ($290) delivered, turns out it was brand new "$688" :-) what a deal! This thing is a beast and twice as thick as my stock rad. Also received my Reische 170F thermostat :-)
Attached Thumbnails Track Related Mods-photo432.jpg   Track Related Mods-photo128.jpg   Track Related Mods-photo911.jpg   Track Related Mods-photo668.jpg   Track Related Mods-photo933.jpg
Old 12/7/16, 01:54 PM
  #508
dmichaels's Avatar
Nice! Do you normally blast the heat at a track day? I started having high coolant issues recently and I've mitigated (for now) with blasting the heat.
Old 12/7/16, 02:42 PM
  #509
SGwick's Avatar
I've never turned on the heat at the track. Never thought about it to cool the engine. I have the stock radiator for the 2011 GT (1 inch thick) and I always run/shift in the high rpms (6800-6950K) using programmed shift light. At road Atlanta (90+F) it over heated and hated doing 1 hot lap and 1 or 2 cool laps after.
Old 12/7/16, 06:58 PM
  #510
5.M0NSTER's Avatar
I really think that between this "fatty" rad and the proper oil cooler with it's own radiator your heat issues will be gone!
Oh, so what's the theory behind the lower temp thermostat? Turns on the fan sooner?
Do you have ideas about why you suddenly developed cooling issues? Are you still on factory antifreeze?
Old 12/8/16, 12:55 PM
  #511
dmichaels's Avatar
The single change i made to the car between never having cooling issues and then having cooling issues was the rear wing. I struggle to connect that as the engine is only working marginally harder.
Yes I'm on stock coolant. I'm going straight water with wetter water additive next year. I also removed my fog lights and added mesh over the openings. I have data from a track day that is an apples to apples comparison to a day with fog lights still installed and i consistently saw 5 degrees or so lower. I'll also note I've only had overheating symptoms at 2 tracks, both of which were new ones for me this year...
Anyways, I'll see what happens next season with my car.
Old 12/11/16, 12:35 PM
  #512
SGwick's Avatar
I read when using water wetter you get better results with straight water. Which type do they mean (tap or diluted water)?
Old 12/11/16, 08:18 PM
  #513
SGwick's Avatar
Distilled. Nvrmnd :-)
Old 12/12/16, 08:26 PM
  #514
Distilled!
You don't want to use tap water!
SGwick (12/12/16)
Old 1/15/17, 06:06 PM
  #515
5.M0NSTER's Avatar
My S04's are done, and I'm looking for a new set of track tires to put on my SVE drift wheels in 19x9.5". Hoping whichever way I go they will last this season and next.
I have to make 2 major decisions:
1) 285/35-19 OR 275/35-19
2) Bridgestone Potenza RE71R, Michelin Pilot Sport Cup 2, Dunlop Dirazza Start Spec etc. Of course the fists decision affects the second decision a lot.
Right now I'm leaning 285/35-19 and Potenza RE71s.
Old 1/15/17, 09:22 PM
  #516
That is the same thing I'm thinking about!
I have the same rims!
Old 1/16/17, 06:22 PM
  #517
EF1
EF1's Avatar
Old 1/16/17, 07:38 PM
  #518
5.M0NSTER's Avatar
I'm worried about going shorter than 27" tires with 3.73 gears. I run out of 3rd already at my home tracks. Now granted, with Steeda CAI/tune I will have extra 400 RPM (7200 Redline) but I don't want to make hanging out at 7100 a common occurrence.
So 285 is more appealing because it's just a hair shy of 27". But 275/35 offers more variety.
So that is my dilemma.
Old 1/16/17, 07:40 PM
  #519
SGwick's Avatar
Go with the tire size/model you listed. I looked into the tire but at 275 and I'm convinced that's my next tire. Great selection and reviews
5.M0NSTER (1/16/17)
Old 1/17/17, 09:31 AM
  #520
Bert's Avatar
Received 1,498 Likes on 1,022 Posts
So 285 is more appealing because it's just a hair shy of 27". But 275/35 offers more variety. . . . .
Can you get the RE71R's in 285/35-19? If so, that sounds like the way to go. I was looking at them on Tire Rack myself recently but don't recall if they offer that size or not and I need to get back to work right now so . . . .
Quick Reply: Track Related Mods
