Mods
#221
Been doing some research and looking at kooks large diameter shorty headers (1 7/8") From what I've read, it'll give me higher end torque above peak rpm and be able to use stock h pipe/cats without a tune. Some low end torque loss for street driving (never really drive above 3.5K rpm on the street) but at the track I try to keep rpm close to 7k so I'm thinking it should work. Thoughts?
#222
Interesting. Personally I'm not a fan of loosing torque. I hear you, gain at high rpm, where your engine lives at the track. I guess I just like twisty force to much.
How is the higer RPM tq look with those headers?
#223
Not kooks but theory
#224
Lol, ashamed to say I really don't drive in the street above 3-3.5K :-)
#225
Originally Posted by dmichaels
This is the mount I use:
https://www.amazon.com/gp/aw/d/B008A...EHL&ref=plSrch
I have two and they work great
#226
I agree, we spend most of out time under 4k RPM, but I have a redline-a-day rule. (at least one).
Today I bounced off the rev limitter twice, once during a burn out, once in 2rd gear. I drive my car like I stole it.
#227
Got my Shiftlight today (plugin ready) :-)
#229
Upgraded Harry's to Grand Prix. I didn't realize it can use GoPro footage and impose Harry's info on top
#232
Just finished installing Blowfish brake duct cooling kit. Wasn't a problem since I had the tools and zip ties needed. Must say a big thanks to dmicheals for cooling duct thread and pictures, I even turned the horns upside down. Used my dremel to remove unused fixtures to make room for ducting. Also installed and setup my shift light. Hopefully I'll reap the benefits at Road Atlanta on the 25 June :-)
#235
SGwick (6/4/16)
#236
Tomorrow is Mid Ohio. I have butterflies in my stomach just thinking about it. I haven't driven there in 10 years when work sent a bunch of us there to do the Acura high performance driving school.
I also tested out a new mounting location for the go pro. Front of the helmet, just above the eyes. Much better view out the window, and still can see shifting.
#237
Mid Ohio looks like a great track.
The fact that you have butterflies and or nervous is a good thing. Just make sure your car is prepped and ready. Keep your focus and you will do fine. Looking forward to some helmet cam video
5.M0NSTER (6/5/16)
#238
So this made me a bit angry yesterday. My brakes at Grattan last weekend were not good. Back end felt loose in straight line braking. I decided to replace the XA6 pads with my XP8s which are 50% or less at this point.
Guess what I discovered??
On the driver side rear, the piston was turned such that the little notches for the peg on on the bottom of the backing plate were horizontal, not vertical. So the pad was not evenly seated against the cylinder, and the cylinder was pushing on the peg, so the top to bottom pressure was uneven. This may help explain my ****ty feeling brakes
I put the XP8s back, turned the cylinder in 90 deg and made sure the pads were seated against the cylinder properly with the peg in the notch. Then I re-bedded the pads. Bakes feel better now as far as I can tell from street driving. Tomorrow will be the acid test.
I'm angry though, I paid a mechanic to do this, and I expect **** like this to be done right. Next time I stop by we're going to have a frank talk.
#239
You'll be fine 5.Monster. Glad you got your brakes worked out. I second what redonblackpony said, can't wait for helmet vids :-) have fun
#240
Received 1,544 Likes
. . . I am excited an a bit nervous, Mid-O is a hell of a course, and I actually work with a guy who has a 2013 GT TP car which he crashed at Mid-0 2 years ago. . . .
On the driver side rear, the piston was turned such that the little notches for the peg on on the bottom of the backing plate were horizontal, not vertical. So the pad was not evenly seated against the cylinder, and the cylinder was pushing on the peg, so the top to bottom pressure was uneven. This may help explain my ****ty feeling brakes . . . ..
I have made that mistake with the rear brakes installation. I found the problem because the rear brakes were burning up in regular driving -- pads were dragging. They got hotter than they ever have on the track. It is a very easy mistake to make. But yeah a professional should know better.
