Winshield glass cleaner
I haven't had much success with stoner's invisible glass, the best results I had was to do a quick wipedown with Isopropyl alcohol and a clean towel after cleaning with glass cleaner. That eliminated all streaks
I actualy dont use any type of cleaner. I was at auto zone and found towel system that works. I dont know the name off hand but there is two one blue and one bright green. I wet one with water and wipe glass and then wipe dry with the other one and it so far has worked perfect. No streeks no smell and no worry about messing up my tint on the inside. I'll try to see what brand it is. This brand has other towels in the line up like a microfiber drying towel and some others I cant remember.
<div class='quotetop'>QUOTE(NJ3 @ May 4, 2006, 3:17 PM) Quoted post</div><div class='quotemain'>
Stoner's Invisible Glass then go over the clean glass with newspaper. (Crumpled and black print only)
[/b][/quote]
So you don't use the newspaper until AFTER you wipe off the Invisible Glass? You just wipe the dry glass with newspaper? I'm so confused! [img]style_emoticons/<#EMO_DIR#>/banghead.gif[/img]
[/b][/quote]
<div class='quotetop'>QUOTE(Rash @ May 4, 2006, 4:03 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
That's how I do it. I use a towel (washed and dried with no fabric softener) to dry and clean the window, then newspaper to finish drying. You can feel the newspaper dragging on the glass until it's completely dry. Oh yea, clean glass while it's cool to keep whatever solution you use from evaporating. On tint I skip the newspaper altogether. I get perfect spot, streak free glass every time. I'm, well for lack of a better term, **** about spotless glass. [img]style_emoticons/<#EMO_DIR#>/baby.gif[/img]
[/b][/quote]
