Help cleaning window trim
Old Feb 15, 2010 | 10:34 AM
BossDawg's Avatar
I need a little help from the car detail gurus around here. Apparently the last time I detailed my car I got some cleaner, polish, or wax on the black window trim which has left a white residue. Any suggestions as to what the best way to get this off of the trim is?
Thanks.
Old Feb 15, 2010 | 11:26 AM
TheIrishMan's Avatar
A simple eraser, or some Simple Green on an old toothbrush should do the trick. If all else fails, Isoproyl Alcohol cut 1:1 with water.
Don't forget to treat the area with a trim restorer after you're done though. Dull gray trim is nasty.
Old Feb 15, 2010 | 11:58 AM
garyb900's Avatar
+1, eraser plus Mother's Back to Black.
Old Feb 15, 2010 | 12:03 PM
BossDawg's Avatar
Thanks for the quick replies guys. I'll give it a shot.
Old Feb 15, 2010 | 12:32 PM
I use back to black also no eraser
07 AU2BOT's Avatar
I use Pig Spit it works great and lasts a long time
Old Feb 16, 2010 | 06:13 AM
05YellowGT's Avatar
Put the back to black on using a tooth brush , it gets it into the grain ...
Old Feb 16, 2010 | 07:17 AM
BlueSkyVert's Avatar
^ Great idea, I am going to try that!
Old Feb 16, 2010 | 07:13 PM
BossDawg's Avatar
That is a good idea.
Old Feb 20, 2010 | 10:16 PM
Jim D.'s Avatar
If you apply a Protectant (though I do use Back-to-Black on my older car) on the trim before you wax, you'll run less risk of staining the trim.
Also, I use FX SynWax, and it really doesn't stain trim at all like a old-style polish or cleaner wax might.
Old Mar 6, 2010 | 09:29 PM
1999 Black 35th GT's Avatar
Meguiar's just released a new product called Ultimate Protectant which in my opinion beats Back to Black hands down. Give it a try first.
Road_Runner
Sep 2, 2024 04:46 PM
iliveonnitro
Oct 7, 2021 06:31 PM
kponypower
Jun 17, 2020 07:17 AM
Sep 16, 2015 06:44 PM
