BlackFire Wet Diamond vs. Crystal Seal
I am pretty new to this, so to me it looks like these products are trying to solve the same problem. What is the difference between them? or probably better stated, when should one be used over the other?
Autogeek links:
Crystal Seal
Wet Diamond
Autogeek links:
Crystal Seal
Wet Diamond
I use both. Wet diamond after your wash and clay (if needed). Crystal seal after the wet diamond has cured for a little more protection. I also use crystal seal to maintain the protection as it's very easy to apply. I use it every 3-4 washes. Takes 15-20 min. tops.
That was a fun thread, thanks for sharing that info. Does that routine leave it slick enough that you don't apply wax?
After seeing this reply, it occurred to me that I had marked one of your posts sometime back: https://themustangsource.com/f659/be...2/#post6712302
Autogeek links:
Crystal Seal
Wet Diamond
Autogeek links:
Crystal Seal
Wet Diamond
Wet Diamond is a traditional liquid paint sealant; you apply it with a foam applicator and let it dry to a haze for about 20 minutes before removing it. Protection lasts 5-6 months depending on environment.
Crystal Seal is a spray on walk away paint sealant; you simply spray it onto the surface and evenly distribute the product using a microfiber applicator. There is no buffing or rubbing required! Protection lasts 3-4 months depending on environment.
A lot of people like to use Wet Diamond as their main form of paint protection, and then apply a coat of Crystal Seal once a month or so.
With either product, you want to make sure you clay and polish the vehicle before application.
Thanks for the reply.
I ordered some Wet Diamond and the BlackFire Montan Wax on the BF discount day. Should be arriving tomorrow. The 12 days discounts are killing me.
Too cold here to clean off the old wax and apply now. But, I am looking forward too it.
unnoticedtrails
Jul 17, 2017 11:10 AM
