Warped Head
Old Jul 9, 2005 | 08:44 AM
sisdavid's Avatar
95 Lincoln MK VIII. I suspect that I have a warped head. If I take the head off and have it fixed. What are the chances of the block being warped too? since the block is also aluminum. How can I tell if it is warped how do I check it? Maybe just a blown gasket. How check for a blown gasket? I took it to the dealer and he said that I had low compression on my number One and Two cylinders. I do not know if this is entirely true because they lie alot. The oil does not appear to be contaminated though.
Old Jul 9, 2005 | 10:38 AM
63galaxie's Avatar
I would hope you don't have a warped block...low compression could mean bad plugs. Your gasket will have a tear in it if its blown. First off i would check the head gaskets to see if they're not blown, then I'd get a tune up and see what happens...
Old Jul 9, 2005 | 11:17 AM
Scothew's Avatar
Stubborn Bear
TMS Staff Retired
do a compression check, thats gonna help you figure it out. May have to pull the motor and have it sent to a machine shop to be checked.
NC14GT
Sep 10, 2017 04:47 PM
Sep 30, 2015 07:02 PM
FromZto5
Sep 30, 2015 05:28 AM
earl610
Sep 7, 2015 11:57 AM
