20in rims!
Then there is the width. If you go with rims all the same width then I would consider at least 8.5 inches wide but no wider than 9.5 inches. Unless you want a staggered setup then the rears can go as high as 10. You want to keep the fronts in the 9 inch range staggered. But can go as high as 9.5 on the fronts if all the rims are the same size. Rubbing will only happen if you exceed these limits or lower the car too far with too big of wheels. I would stay with 18 inch wheels on a V6 just for weight reasons. Plus you can have more tire so that rough roads won't be a major issue and you can do other suspension mods without having to worry about rubbing as much.
But if you can reply with the Boss wheels (link) you are looking at it would help as well! Hope this helps you!
