Window not going down
Old Nov 11, 2008 | 11:35 AM
yugoboss's Avatar
Disconnected my battery on my 09 vert today so i could put the car in storage, and my window stays
up and i can't close the door. I know there is no power now, but i reconnected the battery, and the window does not go down slightly like it used to, in order to open or close the door. Is there some kind of reset procedure ? Thanks !
Old Nov 11, 2008 | 12:39 PM
jayguy's Avatar
yes. To reset your window, with the car turned on, run the window all the way up, then all the way down, then all the way up again. That should reset it. If you want to be able to open and close the door with the battery disconnected, I would suggest opening the door so the window moves down a little, then disconnecting the battery. That crack will always be there, but if you store it inside, under a cover, there shouldn't be a problem with it.
You will probably have to reset the window again when you are ready to pull it out of stororage.
Old Nov 11, 2008 | 01:11 PM
Imatk's Avatar
Everytime I've had this issue I just roll the window up and hold the switch in the "up" position for about three seconds. That fixes it.
Old Nov 11, 2008 | 01:59 PM
adrenalin's Avatar
Just like the manual says, you roll the window up all the way. Let go of the switch, and then hold the switch in the up position for 3 seconds. That resets it. You should now be able to roll the window down and up with no issues. BTW, you can do this without having to start the car. Just put the key in and turn it to the accessory position.
Old Nov 11, 2008 | 02:00 PM
adrenalin's Avatar
Moved to the main forum as this issue/resolution does not pertain to just the GT/CS model.
Old Nov 11, 2008 | 05:23 PM
yugoboss's Avatar
Thanks !
Uofmrampage
Aug 2, 2022 02:55 PM
iliveonnitro
Oct 7, 2021 06:31 PM
kponypower
Jun 17, 2020 07:17 AM
CoyotePremium13
Sep 23, 2015 06:45 PM
5.M0NSTER
Sep 16, 2015 08:00 AM
