Where can I get the Spark tool?
Old Apr 16, 2010 | 06:47 AM
Katfish's Avatar
Arrrrrrrrrrrrrrrrrrrrgh!
I'm changing the sparkplugs on my 06 with only 24k miles. 7 came out ok, of course the 8th broke!
Where did you get the removal tool & tap?
Any suggestions from unfortunate who've done this before?
Service Tool 303-1203 (I assume the tap mentioned in the TSB is seperate?)
Thx
PS: I followed the TSB exactly
Old Apr 16, 2010 | 06:58 AM
Katfish's Avatar
Will this work?
http://cgi.ebay.com/ebaymotors/Ford-...motiveQ5fTools
The tool in the TSB is $300!
Old Apr 16, 2010 | 09:09 AM
cop on my back's Avatar
Buy a 9X1mm tap and tap the hole. Then get a peice of ready rod (threaded rod) the same and use a stack of sockets with a washer and a nut on top to use to draw the part out of the head. I made my own tool (I am a machinist) just like the ones you can buy when I did my F150, 3 of those broke.
Go to a F150 forum and search on this topic. The 5.4 uses the same plugs and there are a few home made kits that work fine.
My buddy has my tool now, he is changing his plugs in his Mustang this weekend.
Old Apr 16, 2010 | 10:59 AM
Katfish's Avatar
Thx for the info,
Found the tool for $75 shipped, I'll go ahead and give it a try. Oh well, I'll just have to drive my beater next week.
Old Apr 18, 2010 | 12:13 PM
mustangbaxter's Avatar
I made my own tool as well, but I used a 3/8 tap, and 3/8 threaded rod!! total cost.... less than 5 bucks
Attached Thumbnails Where can I get the Spark tool?-img_0070-large-.jpg   Where can I get the Spark tool?-img_0072-large-.jpg   Where can I get the Spark tool?-img_0073-large-.jpg
Old Apr 18, 2010 | 12:42 PM
gotta love homestyle machinists!
Old Apr 18, 2010 | 05:29 PM
Katfish's Avatar
The TSB mentions stuffing a vacuum cap down the slug. Any reason to do this, what are the chances some metal shavings will fall in?
How do you know how far to thread the tap/tool before trying to pull it out?
Thx
Old Apr 18, 2010 | 08:00 PM
houtex's Avatar
Stickied... well, ok, maybe bookmarked, but still.
Old Apr 18, 2010 | 09:13 PM
PTRocks's Avatar
Thx
The reason is because there is an excellent chance that the tap will push chips down the hole. Chips will damage the cylinder walls if they get in and the crank is turned.
Old Apr 18, 2010 | 09:27 PM
Old Apr 19, 2010 | 03:18 PM
Thx
I used an oil soaked Q-Tip at the bottom, and lots of axel grease on the tip of the tap to prevent any shaving going down there. Also I just cut about 3-4 rotations in mine, then that metal sleeve started to turn in the head, so I figured I had gone far enough, sure enough, it came right out with no problem!
Tim
Old Apr 19, 2010 | 04:57 PM
Katfish's Avatar
The tool came today. It was comical how easy the plug tip came out. It took longer to read the instructions than it did to use the tool. I did shove a vacuum cap down the tip as a precaution.
Oh well, that little project is over. Anyone want to buy the tool?
Old Apr 21, 2010 | 04:03 PM
white08gt's Avatar
what plugs did you replace with?
Old Apr 21, 2010 | 07:42 PM
Katfish's Avatar
I went with the 1 piece Champions # 7989, $105 shipped from Rockauto
Make sure you google rockauto discount, there's always a 5% discount code floating around.
Old Apr 24, 2010 | 04:01 AM
GrumpysGT's Avatar
Katfish, you have a PM about the tool.
GrumpysGT
Old Apr 25, 2010 | 08:19 AM
Barricade's Avatar
I bought the tool as well cause I always have bad luck doing things like this. lol
Old Apr 26, 2010 | 09:04 PM
Casey4s's Avatar
I bought the Lisle extractor tool as insurance. I knew if I bought the $79 tool in advance I would never need to use it so it was worth the investment. My plugs came out with just a quick soak in break cleaner.
I have loaned it out twice in two months though.
trackpack13gt
Jul 25, 2017 05:29 PM
STOERKEL
Sep 11, 2015 11:38 AM
tang65c
Aug 31, 2015 10:07 AM
GTown3r
1994-2004 V-8
Aug 30, 2015 08:04 AM
