Trunk LED prolem
Got a license plate LED replacement bulb, and a trunk light one for my 05 GT coupe. The license plate one I had no problem installing - it took about 2 minutes and worked like a charm.
Trunk bulb was another story. Its easy enough to get the old bulb out and the new one in, but I have tried every which way as far as flipping the bulb around but I can't get it to light up. Is there a fuse or something I can check?
I had the same problem and the guys at HIDGuy.net told me to bend the connectors to make sure they mold themsleves around the end points of the bulb. I don't know if it would work because I have been too busy with things to spend the tiem laying in the trunk and carefully bending the tabs to make them mold.
Just maybe your trunk was open for over 15 Mins.? It might be **** off automatically if your trunk has been open for a while..
