Tranny Fluid.
Old Mar 25, 2014 | 10:02 PM
2005GeeTee's Avatar
Tranny Fluid.
I just had my tranny serviced at the Good old lube of jiffy. Servise Pro Full Synthetic ATF is what they ended up placing in my tranny. I have never heard of Service Pro. Have you?
Old Mar 26, 2014 | 05:16 PM
NC14GT's Avatar
Just make sure it is OK for your Mustang. Check your owner's manual. Look at this link as there is a warning about some types of Fords under the description with the 'synthetic blend'. You are probably fine but double check. http://www.service-pro.com/documents...leSynBlend.pdf
Old Mar 27, 2014 | 04:42 PM
2005GeeTee's Avatar
Thanks it says it meets or exceeds Mercon and Mercon-V applications. The internet is funny 05 and 06 tranny called for the mercon but after those years they called for mercon v and they have the same tranny. Your link had just the right amount of info to actually know what to look for. Thanks.
Old Apr 2, 2014 | 06:32 PM
Lime GT's Avatar
It's because Mercon has been phased out. It is now replaced by Mercon V.
Old Apr 5, 2014 | 09:33 PM
tbear853's Avatar
From: the beautiful "Shenandoah Valley of Virginia"
There's still "Dexron / Mercon" conventional ATFs that service those applications, the Mercon V is a synthetic that will backwards cover previous Mercons as well as Ford Type H and Type CJ fluids.
Old Apr 5, 2014 | 10:19 PM
Lime GT's Avatar
http://www.aa1car.com/library/ford_tsb_06144.pdf
trackpack13gt
Aug 8, 2015 11:23 AM
Burnhaven
V6 Performance Mods
Jul 23, 2015 11:57 AM
Rog13GTCS
Jul 19, 2015 02:46 PM
Burnhaven
Torch Red
12
Jul 18, 2015 11:41 AM
