TPMS Tire Pressure Monitoring System
Old 5/8/07, 04:33 PM
  #141
Stoenr's Avatar
I was talking to a member today about the TPMS and Realized Why they Got away from the Valvestem Type. Anybody ever try to Reuse a Valvestem. Most times you rip it while removing it. It would be a Safety Isuue reusing the Sensor from one wheel to another!
KC
The snap in style stems can be replaced, I think we are charging 10 per kit.
The service techs just need to be aware when removing one, not just to grab it and pull it out with the sensor still on the back.
Either way, The band style might be the best imo.
I am learning more and more about these every day now that we are starting to see them coming into the shop.
Did my 1st relearn on a GM today, pretty easy.
The Acura MDX we did had auto relearn, very nice.
Still waiting for a Ford with TPMS that needs a relearn.
Old 5/8/07, 04:35 PM
  #142
Stoenr's Avatar
Exactly every time a tire is changed or I think t that valve stem you must redo the stem either the new o-ring kit ? correct ? and tire guys say it's a royal pain to do them.
Heh, absolutly.
We all hate change tho, will just take some time getting use to.
Old 5/14/07, 06:49 AM
  #143
2005GTDELUXE's Avatar
so can you buy a 16" V6 tps for a Magnum wheel?
Old 5/15/07, 02:38 PM
  #144
The Analog Admin!
05stangkc's Avatar
Received 2,992 Likes on 2,199 Posts
The Sensors are the Same. Just a Matter of getting Some New Straps.
Old 5/15/07, 08:59 PM
  #145
bob
bob's Avatar
Chrysler also has some vehicles equipped with an auto relearn, On your GM vehicle, was it the type that used the magnet oir the scanner, or did you do the trick where you deflate the tire till the horn sounds then repeat the process around the vehicle.
Old 5/15/07, 09:25 PM
  #146
Stoenr's Avatar
No, we put the car into learn mode using the message center options. (Now is when normally you would use the magnet or air psi trick) Put the handheld TPMS reader to the LF,RF,RR,LR and it wakes up each sensor as you go to each wheel. Horn beeps after each one, then twice when complete, have a nice day.
Old 7/18/07, 03:29 PM
  #147
cinque35's Avatar
What do you have to do to get your car to recognize new wheels with the sensors in them?
And then will it still know the old ones?
Old 7/18/07, 03:31 PM
  #148
Stoenr's Avatar
They need to be woken up with a progammer. Then programmed.
Not sure but I think the old ones lose the communications at that point with the BCM, not sure.
Old 7/19/07, 10:08 AM
  #149
cinque35's Avatar
thanks, i'll have to ask the dealer.
these things are completely useless anyway, i changed my wheels and the light didn't come on until over 50 miles later!!!
Old 7/20/07, 09:13 AM
  #150
The Analog Admin!
05stangkc's Avatar
Sounds Like Some of my Employee's!
MGB,
KC
Old 7/25/07, 07:11 PM
  #151
GoFaster's Avatar
Need to be woken up, eh? Maybe that's why I'm getting a Low Pressure warning after swapping from fanblades to factory GT500 wheels & tires.
After the fun of buying the car (and knowing more about it than the salesman) I can't imagine how much fun it'll be to talk to the service dept about this.
Old 7/25/07, 08:21 PM
  #152
cinque35's Avatar
Good luck! apparently nobody knows anything about them..
Old 7/25/07, 08:33 PM
  #153
RobK's Avatar
I had my dealer learn in the new set that came with my wheels from the Tirerack. They did it in a couple minutes gratis. They have a handheld tool for setting them up.
Old 7/26/07, 01:16 AM
  #154
sycd's Avatar
You're lucky. My dealer quoted me $100 for the same thing
Old 7/26/07, 08:12 AM
  #155
RobK's Avatar
Go to another dealer. It's a 15 minute operation tops. Is their rate $400/hr.?
Old 7/26/07, 11:36 PM
  #156
ArmourChad's Avatar
Here's how I worked around the TPMS light, which at first I didn't think would be a problem but after a while really got on my nerves.
I went to HomeDepot and bought a 12" X 1 1/2" threaded PVC pipe and matching threaded caps and a can of PVC cement. Then I went to PepBoys and bought a threaded valve stem 1 1/4". Put the offending TPMS sensors in the pipe, drilled a hole in one of the caps and installed the valve stem. Pressurized the pipe bomb looking contraption up to 35PSI and the TPMS light has been gone ever since. Total cost $16.00.
Here's a picture of the fix, that is placed under the rear decklid, and out of sight (Not very appealing) I got this idea from another forum and this is my first post here.
http://i63.photobucket.com/albums/h1...IMG_1141_1.jpg
Old 7/27/07, 02:58 AM
  #157
Stoenr's Avatar
From what Ive read the sensors need to be pulled out of sleep mode by speeds of 20 mph+. Pretty sure they sleep when the car is off for battery live in the sensors.
I wonder how long the PVC trick will work. Keep us up to date, I have not followed the others who have tried this.
Old 7/27/07, 07:07 AM
  #158
jstang's Avatar
Why bother with installing the sensors? Especially if you have to take them to the dealer for "learning." That plus having extra chunks of metal/plastic inside your tires and having to eventually replace the batteries. TPMS might be worthwhile for the kind of drivers that typically neglect their vehicles, but for performance car drivers they seem to be more trouble than they are worth. ($400+ for Tire Rack to install.)
My experience with my summer tires is that the warning message comes on when you start the car - press the restart button and it goes away. The low pressure light comes for a couple of seconds and goes away. Overall, its less annoying than the low fuel warning system.
Old 7/27/07, 07:34 AM
  #159
RUgoinUp?'s Avatar
$40 for new bands/cradles from Discount Tire, and they reuse your sensors from the stock wheels. The sensors will relearn on their own, either immediately, or after a few minutes of driving. I don't see why this is such a big deal.
Old 7/27/07, 08:00 AM
  #160
jstang's Avatar
This works if you have worn out your old tires. You still need to break down the old tires/wheels, retrieve the sensors and, if you are buying from Tire Rack or Discount, ship them for install. If you want a second set(summer and all-season), you need new sensors.
Quick Reply: TPMS Tire Pressure Monitoring System
