Tie rod replacement
Old Aug 9, 2010 | 07:20 AM
Paris MkVI's Avatar
Tie rod replacement
She's a 2006 GT vert with about 70k miles. Daily driver with very little track time. Mechanicals, suspension is factory original.
I've noticed a little bit of front end steering shimmy at low speeds (~25mph).
While in for a recent service, the informed me that a tie rod needs to be replaced. I suspect a connection between the shimmy symptoms I noticed and this diagnosis. Your opinions?
I presume the design has both inner and outer tied rod ends? Do you think I should just replace both sides and be done? Your opinions?
Old Aug 9, 2010 | 12:38 PM
kingofsting's Avatar
that sounds about right..i had the same thing happen on my 05 DD about a year and a half ago at around 60-70k. I believe they had to replace the drivers side tie rod and the balljoint to solve the issue...no problems since!
Old Aug 9, 2010 | 05:06 PM
ford4v429's Avatar
legacy Tms Member
Ive noticed(2years ago!!!) that the rubber was already deteriorating on my balljoint and tie rod boots- surface cracks at all the accordionlike folds...the big fat rubber control arm bushings are cracked too...the wifes 07 looked similar when it only had about 9k on it.
they had a valvestem issue due to cheep chinese rubber, I'm guessing the same thing might be occurring here...I wipe armorall over the boots when I go under it, but wether it will help slow degrading is hard to say.
I think the first 'aging' issues to start popping up will be rust behind the flap in front of the rear tires(posted pics of missing undercoating allowing dirt/water betweemn inner/outer rockers) rust at the bumper/front fender junction(flat shelf catches dirty water running off fendrlip, downward pinchwelds behind headlight catch dirt and flat surface of fender/bumper joint collects dirt- look behind your airbox snorkel with a flashlight), and poor quality rubber suspension parts deteriorating. I heard the control arm/balljoint is sold as a unit? could get pricey...just my predictions- time will tell.
Rando
Aug 25, 2021 11:12 AM
kponypower
Jun 17, 2020 07:17 AM
09-gt/cs
Oct 15, 2015 10:03 AM
PonyMuscletang13
Sep 29, 2015 09:40 AM
