Seat Cover TSB
Old Apr 11, 2006 | 10:36 AM
GaryK's Avatar
Has anyone attempted the repair explained in the seat cover TSB? Is this something worth going to the dealer for, or is it easy to do yourself? Do I have to remove the seat to do it? Thanks in advance for the help.
Old Apr 11, 2006 | 10:39 AM
adrenalin's Avatar
If you are referring to where the seat keep coming loose under the frame (behind your feet), it looks like all they do is drill a hole through the plastic, hook it back on and then insert a cable tie to prevent it from falling again. At least that is what they did to mine. Regardless, look at it this way, if you have any other problems with the seat and you end up fixing the current issue yourself, that might just give them enough reason to void the warranty on the rest of the cover. Ya never know, some dealers are nasty. Just ask them what would happen if you repaired it yourself.
Old Apr 11, 2006 | 12:18 PM
wyldv6's Avatar
I did the repair with nothing more than a pair of needle nose pliers and a dime. The TSB explains how to do it, just take your time and go slowly.
Since I did it I've had no problems whatsoever with the seats. All the TSb does is lets the plastic tab actually snap into the space allowed for it. Seems the slot stamped out is not quite large enough so it has to be bent open just a touch more.
Old Apr 19, 2006 | 04:21 PM
GaryK's Avatar
I was able to snap the clip on by hand, let's see if it holds. Thanks for the advice!
Old Apr 20, 2006 | 12:48 AM
Original Sin's Avatar
<div class='quotetop'>QUOTE(GaryK @ April 19, 2006, 4:24 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
It won't, mine (both driver and pass. seat) keep coming off. I'll be doing the fix 'cause it's driving me nuts because its such a stupid, insignificant little thing [img]style_emoticons/<#EMO_DIR#>/headscratch.gif[/img]
Old Apr 20, 2006 | 09:36 AM
jimh90sc's Avatar
Before the TSB came out, I tried some double - sided tape. This has held ever since.
Old Apr 20, 2006 | 08:51 PM
rickoshay's Avatar
I did the TSB fix today...there was a very positive "click" when the plastice piece was snapped onto the seat frame. [img]style_emoticons/<#EMO_DIR#>/thumb.gif[/img]
kponypower
Jun 17, 2020 07:17 AM
yabutt
Oct 23, 2015 01:05 PM
Evil_Capri
Sep 25, 2015 12:56 PM
robjh22
Sep 23, 2015 07:03 AM
