Replacement Clutch
Old Mar 27, 2012 | 09:54 PM
sdsguy's Avatar
Replacement Clutch
I have a 2008 Bullitt, when I bought the car in December she had around 37,000 miles. I've only put on around another 3,000 since. Anyways, to get to me question, I'm looking to buy a new clutch. The one in the car is fine, but I can tell it's getting ready to go. I don't make bank, so I'm trying to save now to buy the clutch and get it installed. Question is, which clutch do I go for? The car itself has a Steeda CAI, BBK Throttle Spacer, and Borla Cat backs. I know I don't need a super heavy duty clutch, but I'd like to buy one that will be pretty durable since I'm not the best stick shift driver. I don't plan on doing any other mods like a super charger (at least not till she's paid off ) to worry about excessive power but I might get a tune. I went on American Muscle and saw the Exedy clutch, it seems pretty good for the price. I can get a higher rated clutch with all the parts at the same price as the OE clutch.
Also, what should I look for in the kits when buying, such as the necessary parts? When I was on American Muscle, one kit was missing the slave cylinder the other kit has one. I want to be sure I have all the necessary things when I get it installed.
Old Mar 28, 2012 | 06:51 AM
05YellowGT's Avatar
I have an Exedy 500 and it's been a good clutch and it did come with a slave cylinder. I also put a SS clutch line on for the higher pressure , it didn't cost anymore labor while doing the clutch install ...
Old Mar 28, 2012 | 07:07 AM
Doogie's Avatar
Same here as I have a Exedy 500/flywheel going on my car within the next couple weeks as my stocker did not like the hard launches last fall with DRs.
Old Mar 28, 2012 | 11:56 AM
Imatk's Avatar
I ran a centerforce, then exedy clutch in my '06 when I had the 3v in there but the stock clutch was always the best performer.
I was at around 400rwhp with the blower too so unless you drag race a lot I'd say keep the stock clutch.
Old Mar 28, 2012 | 05:39 PM
Got Oatz's Avatar
Plus 3 on the Exedy 500. Went in my car about a month or so ago. Love it so far. Be aware OP that the pedal is a bit heavier than stock with the Exedy, but not too bad. Used to it now. Won't go back.....
Old Mar 30, 2012 | 04:32 PM
Kevin509's Avatar
My first question is why is the clutch bad with only ~40,000 miles? Has the car been tracked a lot? If you say it's "fine" now, how can you tell it's "getting ready to go?"
IF it does need a new clutch, I say go with the Exedy 500 as others have said.. just seems odd to me.
Old Mar 30, 2012 | 07:35 PM
area5179's Avatar
I can't comment on the type of clutch to go with but I will ask why you think it needs to be replaced at only 37k. I had to replace my clutch and flywheel at 50k because of TSB issue that was out of warranty. $1500 later I had a set of new brakes, new clutch, new flywheel and new engine seperator plate. Apparently the engine plate was rubbing on the flywheel and made a horrible metal on metal scraping sound on startup. I did the brakes because it was at 50k and I just wanted piece of mind so I got new pads on all 4 wheels and had the rotors done to be safe.
Old Apr 9, 2012 | 02:36 PM
sdsguy's Avatar
The clutch is still working, I don't know how the previous guy drove it. Basically, I'd rather buy a clutch now while I have the cash and wait till it goes and hopefully by that time have the money ready for install. In my last car was learning how to drive stick so I wore that clutch out pretty quick.
Old Apr 9, 2012 | 02:39 PM
AlsCobra's Avatar
A Man Just Needs Some....
I'm running a Spec 3+ and it's a great clutch. 2+ would be a good option in your car.
Rando
Aug 25, 2021 11:12 AM
kponypower
Jun 17, 2020 07:17 AM
Gill5oh
Oct 6, 2017 10:50 PM
PonyMuscletang13
Sep 29, 2015 09:40 AM
