Rattle from Trunk
Old May 27, 2014 | 04:49 PM
Someguy's Avatar
Rattle from Trunk
Howdy, Im new to the fourm, looking for some answeres. Bought a 2007 gt with 15,000 miles on it, looks and runs flawless, Has rattle that sounds like its in the trunk. Tire and jack are tight, and secure. Its driving me nuts. Please help
Old May 27, 2014 | 04:52 PM
Check if your muffler clamps are tight and not rubbing.
Old May 27, 2014 | 05:05 PM
AzPete's Avatar
Did you remove the spare and jack and check for loose things laying around.....then drive it without said tire and jack just to eliminate areas.
Old May 27, 2014 | 06:39 PM
houtex's Avatar
In addition to the above...
Lower control arms. (This is a current one of mine... that'll be rectified soon. The front bushing on the right one is shot, and rattles.)
Latch/CHMSL cover (This was one of mine... I still haven't put it back on yet... )
And while I'm at it, the sway bar linkage, as well as the panhard bar and brace, and the UCA and body mount.
Old May 27, 2014 | 07:31 PM
ford4v429's Avatar
legacy Tms Member
my wifes 07 had a swaybar link break in the rear...weird it was barely welded together, one bushing end just popped off... just welded it back on, it was rattling.
check the glow in the dark trunk release handle on the trunklid too- it might hang against the trunklid if not stuck to the velcro (at least I think theres velcro on it- or maybe i added that?)
Old May 27, 2014 | 08:16 PM
Lime GT's Avatar
Rear license plate/bracket?
Old May 28, 2014 | 05:53 AM
NC14GT's Avatar
My '07 GT had a similar noise at about 15,000 miles too. I discovered it was just the spoiler being a bit loose. A quick tightening up and the noise never came back.
Old May 28, 2014 | 06:26 AM
Shotokan1509's Avatar
Think its a clip from teh factory but I've seen a lot broken
Old May 28, 2014 | 06:27 AM
If it's more of a clunk, might be the UCA mount has a loosening bolt
Old May 31, 2014 | 05:29 PM
Agent MOO's Avatar
Also check the clearance of the driver side exhaust to the panhard brace.
Old Jun 27, 2014 | 02:22 PM
Someguy's Avatar
rattle in trunk
Thanks for all of the suggestions, it turned out to be a combination of loose hinges, and the trunk lock striker, loose. All taken care of. But thanks again
Old Jun 27, 2014 | 10:15 PM
houtex's Avatar
Glad ya found 'em!
Old Jul 2, 2014 | 05:25 PM
kd4gij's Avatar
I think his trunk monkey has ben playing games.
TMDM
Sep 24, 2015 07:00 PM
BigHoss
Sep 21, 2015 10:03 AM
khoy37
Sep 15, 2015 07:10 PM
robjh22
Sep 8, 2015 12:31 PM
apial
Sep 6, 2015 10:40 AM
