Issue with clutch? I think?
Old Jun 26, 2011 | 09:06 AM
DPHC13's Avatar
I have a 2008 5-speed V8 GT. OK heres my problem. when I start off in first gear it kinda sounds like a coffee can full of marbles right when the clutch engages. then it just sounds like the typical mechanical mess of gears and and stuff spinning. I never thought this sounded right but I never had a 5-speed V8. so anyway the thing that really has me worried is that when I am stopped and let out the clutch it sounds like something is dragging. if I have the car in gear and then put the stick in the neutral position and pop out the clutch i can feel the car kick a little and there is kind of a faint grinding sound. Now if I push in the clutch and pop it again it's fine. Then if i put the car in gear and take it out again and pop the clutch the same thing happens. Does this sound like a clutch or throw out bearing problem or a trans problem?
Old Jun 27, 2011 | 12:52 PM
Imatk's Avatar
It sounds like your clutch isn't fully disengaging.
It could be the input shaft needs to be lubricated... or it may be something else.
I'd definitely take it in to have it looked at.
Old Jun 27, 2011 | 02:03 PM
DPHC13's Avatar
So i guess thats NOT covered under warrantee cuz it's part of the clutch. .... Sucks. I've been hearing this sound for months. now I have over 40K on the ODO.
Old Jun 27, 2011 | 04:47 PM
Imatk's Avatar
Well the input shaft isn't on the clutch it's part of the transmission. So it would not fall under "normal wear" items.
Road_Runner
Sep 2, 2024 04:46 PM
kponypower
Jun 17, 2020 07:17 AM
Gill5oh
Oct 6, 2017 10:50 PM
09-gt/cs
Oct 15, 2015 10:03 AM
