Hurat Shifter Issue?????????
Old Mar 20, 2007 | 02:37 PM
davesiar's Avatar
So I installed my Hurst shifter about a month ago, and love it. The only issue I have with it, maybe its normal, is that when in neutral, it does not spring back to the center between 3rd and 4th. For example, if I am sitting at a stop light and my car is in first gear, and I put it into neutral, the shifter stays toward 1st and 2nd. Is this normal?? Did I over tighten something?? Did I just get a bad shifter?? It also does this if I am in reverse or 5th, but not as bad. Thanks for any help.
Old Mar 20, 2007 | 06:25 PM
dkegel's Avatar
It should sit between third and fourth when in neutral. I wonder if you installed it properly? You may have it rotated 180 degrees (remember that one side of the bottom of the shifter is offset further than the other).
Dave Kegel
Road_Runner
Sep 2, 2024 04:46 PM
kponypower
Jun 17, 2020 07:17 AM
Jul 8, 2016 08:53 AM
09-gt/cs
Oct 15, 2015 10:03 AM
