How to Store for 6 weeks!
Old Feb 28, 2005 | 07:45 PM
hiflyntdwg's Avatar
I am going on TDY for 6 weeks and I have to store my new baby. I was wondering if there is anything that I should to to her before I store her in a storage unit. I live in Northern California so it does not get below 40 deg here. Should I have somebody go by once a week and start her? Any suggestions would be appreciated. Thanks!
Old Feb 28, 2005 | 07:48 PM
jwede's Avatar
You will be fine for 6 weeks. Just park it.
Old Feb 28, 2005 | 07:50 PM
05GT-O.C.D.'s Avatar
I lust for a M24
Just park it, throw a blanket on top, and don't give ANYONE your keys!!! Starting it once a week will cause more harm than letting it sit for those 6 weeks.
Old Feb 28, 2005 | 08:09 PM
bullittman's Avatar
FWIW, I've had mine in storage since Nov (Inside ,covered,room temp). I have had occassion to move the car twice....and my battery was drawn down to zero both times ( Several weeks between). I don't know if its a problem on the car or that the systems draw a lot of amps. (manual says max draw is .05 amps). You might want to disconnect battery. :notnice:
Old Feb 28, 2005 | 08:27 PM
woody1's Avatar
B) For anything more than about 3 weeks with potential temp below 60° I Ditto the battery disconnect comment. Or get a voltage sensing trickle charger if power is avaiable. You'll be fine either way
:flag2: BTW thanks for serving
Old Feb 28, 2005 | 09:33 PM
Badsnke98's Avatar
I second the battery disconnect especially if you have the A-A-T option, it will drain the battery. Just loosen negative cable and lift off post. You will need a nonconductive material (rubber, wood), to place between post and cable. This cable will not bend out of position.
Diode Dynamics
Jun 12, 2018 03:26 PM
Mpaps
Oct 11, 2017 08:06 PM
radio
Sep 17, 2016 03:37 PM
Cobiecane
Oct 23, 2015 08:44 AM
Steve@CJPP
Sep 3, 2015 10:43 AM
