Ford P.O.S. Battery
#81
That's what I thought as well, until Charlie (metroplex) just brought up that he stored his 07 GT a couple of winters ago w/o using a battery tender, with the Shaker 500 turned off in the CD mode, along with arming his active anti-theft system. And yet his battery still remained strong in the spring.
So once again, I'm completely stumped. Although I agree 100% about how the interior motion sensors, are a larger draw on the battery than other sensors
#82
#84
Thanks once again, for clearing everything up Pete.
#85
I forgot to mention my test results of 0.1milliamps, were performed while the car was unlocked, along with the active security system disarmed. Otherwise there would've been quite a noticeable difference in the results.
#86
I do NOT have the active alarm system and my battery dies within a couple of weeks now. Once you have over-drained your battery once or twice, it is pretty much shot. So...maybe it is a Shaker500 issue. The darn thing tries to kill the battery as soon as I connect it up by swapping discs around. Also, my shaker has been known to lose its mind sometimes. It would be nice to have a radio that shuts off when it is supposed to.
#87
Add me to the dead battery club...
Car ran fine last night. Today... turn the key and just a single click. Stone cold dead. Time to get a new one. Any issues with the BX40R (upgraded battery)?
I can't say you guys didn't warn me!! The OEM battery didn't even last 3 years!!!
#88
#89
#90
All this tender and "driven regularly" stuff is wonderful and all, but mine kicked out, and it's my only car so is driven almost every day....so the battery died even though it was driven regularly.
As for the overbearing electronics, well, as much as I wish it were so, I can't ensure that I go for a drive every day. Sometimes, it sits in the port for a day or two. I might expect there to be an issue if there was a fault, or if I had added some extra components to the car...but it's stock. Knowing that, for whatever reason that's causing the drain (logical or not) it's a problem. I mean, who would buy a TV if it only worked if left on all the time? Or a washer where the tub had to be kept spinning?
A machine that renders itself inoperable by design is a little funky, don'cha think? I got a grandfather clock down the hall that has to be wound every other day. Are we now required to do the same for our cars?
I haven't looked (mainly because I'd rather not find such a thing is true) but does the manual say "In order to use the alarm system you must drive the car every day."??
#91
I am unsure why people are blaming the alarm system or Shaker 500/1000 because I stored my Stang for over 6 months about 2 winters ago without a maintainer. I armed the alarm system and manually turned off the Shaker. When spring came, it fired right up.
I still suspect either: faulty Shaker amplifier or a faulty SJB. Get one of those clamp ammeters and put them on the battery positive cable. See how much current is leaving the battery and start pulling fuses until it drops. Chances are pulling the radio fuse may keep your battery alive.
#92
Well don't think ALL dead battery's are from the same cause/effect.
Dead battery could be one of many things wrong.
Just so happens that in most cases its the 'not driven/started enough' category,
but it most certainly isn't the only cause of such a problem.
Could be one of numerous electrical faults and issues
#93
The not being driven excuse is just Ford covering its a$$ in warranty-related replacements of the batteries. It is unlikely for a modern battery to completely discharge without being used within 30 days. The parasitic draw has to be abnormally high to do this. The electronics like active anti-theft and the radio were designed so that the stand-by current draw does not kill a battery too early. Not every car at a dealership is going to be driven or operated long enough to fully charge up a battery.
#94
True, and if I knew I was going to be keeping it in the stable for a long period of time (couple weeks or more), I would address the battery, same as any car. I'm just miffed bc mine keeled over even tho I DO drive it regularly. I think the longest span of time I've gone without driving my 'Stang is maybe 8 days.
#95
Whether it's an excuse or not, there's a reason behind Ford stating the non-usage drivability factor, in it's TSB.
As for cars at dealership lots, that sit around from not being operated or driven long enough, do indeed end up with completely discharged batteries within 30 days.
In fact my dealership in particular, has encountered these very same issues quite often, in which each of their vehicles require some form of jump starting.
As a matter of fact, prior to the delivery of my 2005 GT. My dealership's sales rep. recommended that I purchase a battery tender, in the event the vehicle is neither driven or operated enough.
So why would a sales rep. recommend such a thing, unless he knew something first hand, through his dealership's own experience !
mustanglindsey
8/3/15 09:07 AM
