Console Problem
I have a 05 GT ragtop, the center console is out of line on the left side. If I run my hand down the side of the console it is not flush like on the right side. A buddy of mine has a 05 hard top and his is out of line on the right side. If you all would check your tangs by running your hand down each side of the console and see if it is flush on both sides. Please give some feed back before I go to the dealer. My buddy and I are going with both cars so they can't claim it should be that way, If so why is mine on the left and his on the right. I also can feel a metal clip about 1 inch long on mine when I run my hand from front to back. Please check yours and leave a post. Thank You all before hand.
Correct me if I am wrong, but the center console just slips in place in the front of the shifter and is screwed in place inside the armrest. If that is correct you should be able to loosen the screws and realign it easily.
<div class='quotetop'>QUOTE(adrenalin @ April 17, 2006, 1:45 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
I was always better at DESTRUCTION than CONSTRUCTION and for 32 grand I think it is Ford's job to fix it. LOL. Thanks
[/b][/quote]
<div class='quotetop'>QUOTE(dprestia @ April 17, 2006, 2:33 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
So far 43 people read the post but no replys. Nobody has anything to say? come on group a little help would be greatly appreciated. Please check your consoles. Thanks
[/b][/quote]
<div class='quotetop'>QUOTE(dprestia @ April 17, 2006, 10:42 AM) Quoted post</div><div class='quotemain'>
[/b][/quote]
My console is flush on both sides with no indication of any clips anywhere.
[/b][/quote]
<div class='quotetop'>QUOTE(Zig-Zag @ April 18, 2006, 12:40 AM) Quoted post</div><div class='quotemain'>
[/b][/quote]
Thank You. At least someone checked. Now I know my buddy's and mine are wrong.
[/b][/quote]
Mine was out on the Passenger Side, actually felt it before I saw it.
My Dealer's Body Guy used a thin flat tool to force it into
the proper position. One plastic tab was on the outside, instead of
in.
No further problems.
in.
<div class='quotetop'>QUOTE(vistablue mustang @ April 18, 2006, 8:27 PM) Quoted post</div><div class='quotemain'>
Flush on both sides
[/b][/quote]
Thank You Vistablue.
Flush on both sides
[/b][/quote]
<div class='quotetop'>QUOTE(Mach 73 @ April 21, 2006, 4:04 PM) Quoted post</div><div class='quotemain'>
Flush on both sides -- 05 GT coupe -- easy fix @ dealership.
[/b][/quote]
Thank You MACH 73
[/b][/quote]
Thank You MACH 73
Rando
8/25/21 11:12 AM
