Clutch/tranny issue?
Old Nov 13, 2013 | 03:52 PM
05PRMTX's Avatar
I'll describe this the best I can and try to get a video with sound. When I put my foot half way down or more, the rpms fly up immediately by 1k-1500, almost like its in neutral. Holds there until i back off a little or the transmission catches up I guess. I have a V6 5spd. Is this maybe the clutch not biting under a harder load? Seems to only do it when at 2K-4K rpms
Old Nov 14, 2013 | 11:23 AM
05PRMTX's Avatar
Ok, here is a video of whats happening when I push the gas 1/4 of the way or more down. Hopefully somone can tell what is going on from this.
http://www.youtube.com/watch?v=Yp_Le...ature=youtu.be
Old Nov 15, 2013 | 01:58 PM
MineralGT's Avatar
Sounds like a slipping clutch. 2-4K RPM is getting into the torque curve putting extra stress on it. How many miles do you have on the clutch? May just need an adjustment.
Old Nov 16, 2013 | 10:11 AM
tbear853's Avatar
From: the beautiful "Shenandoah Valley of Virginia"
Sounds like the clutch is wore out, you'll need a clutch job .... and maybe even a flywheel as you are creating a lot of heat every time you do those flare ups.
No adjustment, linkage is hydraulic 2005 up and self adjusts.
Old Nov 18, 2013 | 11:49 AM
05PRMTX's Avatar
That's kinda what I was worried about. I drove pretty cautiously last week as to keep flare ups to a minimum. Ironically I have not had any issues with it since Wednesday of last week. It was pretty cold here in Houston for about 2 weeks (40s-50s). Then at the end of the week it got back up into the 70s and 80s. Could this have anything to do with it?
Old Nov 18, 2013 | 11:59 AM
05PRMTX's Avatar
I'm the second owner of the car and it has about 86K miles. I'd have to scroll through my info from it and see if/when the original was replaced. Off the top of my head I'm pretty sure its the original. Not sure what the normal clutch life is for this car.
Old Nov 18, 2013 | 01:06 PM
LivinTheStangLife's Avatar
Clutch life all depends on the driver and whether its tracked/driven hard/shifted incorrectly or not. My 04 v6 I got 150,000 miles before I replaced my clutch and that's only because the throwout bearing went out and I was already in there. The friction material still looked pretty decent on the old one
Old Nov 18, 2013 | 02:45 PM
05PRMTX's Avatar
Ok, well its my DD so I am not very hard on it. It's never been tracked, I don't launch it. I don't use the clutch to hold me on hills, ect. Ill miss a gear every now and again but that's about it. What's throwing me the most is the problem stopped. I haven't had any issues with it grabbing since Friday.
Old Nov 19, 2013 | 12:00 AM
What year is it? 05 & up switched to hydraulic which I am not a fan of. Maybe it's in your clutch hydraulic system
Old Nov 19, 2013 | 11:26 AM
05PRMTX's Avatar
It's an 05. Yea, Ill probably get it looked at this week. I was just really hoping to avoid a new clutch already lol
Old Nov 21, 2013 | 09:57 AM
FordService's Avatar
Hello 05PRMTX,
You should bring it into your dealer and have it checked out. Your service manager is in the best position to let you know if there is work needed, and any coverages, recalls, or assistance available.
Also, remember repairs done at a Ford Dealer come with a 24 months/unlimited miles warranty. Let me know the outcome.
Deysha
Road_Runner
Sep 2, 2024 04:46 PM
kponypower
Jun 17, 2020 07:17 AM
09-gt/cs
Oct 15, 2015 10:03 AM
Antigini-GT/CS
Oct 5, 2015 09:43 AM
