think i got my cold start squeeling problem figured out
Old Nov 17, 2013 | 01:22 PM
jcopin's Avatar
I finally got fed up enough to do some investigating while I had the car cold in the driveway before winter hits and jacked the car up and started it.
checked exhaust...nope
put a tube to the transmission..nothing
with the car jacked up it seemed the noise moved up more towards the front of the car. looks like the harmonic balancer is wobbling slightly so I took the belt off and no play at all.
then I decided to spin the water pump pulley....SQUEEEEEEEEL just moving it by hand. think I found my culprit even though I have never had any leaks. is this squeal normal for the water pump or did I finally find the noise that has eluded me for 4 years now..
Old Nov 17, 2013 | 02:12 PM
EastTNMustang's Avatar
Originally Posted by jcopin
I finally got fed up enough to do some investigating while I had the car cold in the driveway before winter hits and jacked the car up and started it. checked exhaust...nope put a tube to the transmission..nothing with the car jacked up it seemed the noise moved up more towards the front of the car. looks like the harmonic balancer is wobbling slightly so I took the belt off and no play at all. then I decided to spin the water pump pulley....SQUEEEEEEEEL just moving it by hand. think I found my culprit even though I have never had any leaks. is this squeal normal for the water pump or did I finally find the noise that has eluded me for 4 years now..
You found the noise...water pump is on its last legs. Replace it, but still confirm that nothing is rubbing on pulley?
Old Nov 17, 2013 | 06:04 PM
jcopin's Avatar
There is nothing running on it. This noise has only gotten worse over the last 4 years and is terrible when is is cold outside and the car has sat overnight.
Old Nov 23, 2013 | 05:18 AM
Have you had a chance to change the water pump yet? Did it fix the noise?
Old Nov 23, 2013 | 07:19 AM
SilverSkoundrel's Avatar
the water pump on my 4.0 does that. idk if its the same pump or not
mustanglindsey
Feb 15, 2026 04:48 AM
SpaceCitySPY
Mar 30, 2016 09:45 AM
Beavis9000
Aug 10, 2015 12:16 PM
Fastryker
Aug 7, 2015 05:28 AM
ClayP
Aug 3, 2015 09:00 PM
