Broke antenna off....!!
Old Jun 11, 2018 | 07:22 PM
OneCoolGT's Avatar
I got a new car cover and needed to make a hole in it for the antenna and when I was going to remove it, it turned a little bit then snapped. I attached a pic of what's left, is there a way to get it out or am I screwed into buying a whole new unit? I have satellite radio and don't listen to the radio but it looks ugly now without an antenna.... can it be drilled out?
Old Jun 12, 2018 | 05:41 AM
05YellowGT's Avatar
First spray some penetrating oil or spray on it and let it set for a while, that'll help loosen it up. Then it looks like you might have enough sticking up to use a dremel tool with a cutoff wheel. Cut a notch in the top and then use a flat blade screw driver to try and remove it. Other method is to drill a hole and use a pipe nipple extractor, if you can find one small enough. I have the set in the link below, but I'm not sure if the smallest one is small enough. Good luck ...
https://www.homedepot.com/p/HDX-Pipe...X167/204218641
Old Jun 12, 2018 | 10:48 AM
tukatz's Avatar
I installed one of these on my '14 and it looks a whole lot better.
https://tinyurl.com/y8ooe4y8
Old Jun 12, 2018 | 01:19 PM
OneCoolGT's Avatar
Thanks! I have a dremel tool and will give it a shot.. hopefully it'll work!
Old Jun 12, 2018 | 06:39 PM
Spot on but maybe a vice grip first if you've got enough to bite into.
Old Jun 22, 2018 | 06:54 AM
dly's Avatar
dly
screw extractor left handed drill bit
Old Jul 2, 2018 | 11:53 AM
2015GT350's Avatar
Or go here and on the top box, type in "Antenna" and click the search button to see how much a new one is. At least that's OEM and everything should fit like it's supposed to. Not too expensive.
Earlsays
Feb 1, 2015 01:28 AM
SD6
'10-14 Exterior Modifications
Mar 21, 2011 09:49 PM
Badsnke98
Jul 28, 2005 03:27 PM
pumpkinfish
14
Jun 12, 2005 09:59 PM
southern_stang_girlee
Off-Topic Chatter
Apr 26, 2005 02:14 PM
