Better & easier way to reset the ECM
Old May 10, 2008 | 06:27 PM
losamigo's Avatar
When the need to reset the ECM/PCM, such as relearning the throttle, or auto trans adaptive values, many are disconnecting & reconnecting the battery. This does the job, but results in loss of radio presets. A better way to do this & keep the radio presets is to pull & reinstall fuse 45 (red 10A) under the hood, which is keep alive power for the ECM. It also requires no tools (if your fingers are small enough), and no danger of arc welding by accidentally shorting the cables.
Just my 2 cents...
Old May 10, 2008 | 07:50 PM
theedge67's Avatar
Good info, this will save many radio presets.
Old May 10, 2008 | 08:41 PM
302svt's Avatar
Interesting
Old May 10, 2008 | 09:52 PM
Faber's Avatar
awesome! thanks
Old May 10, 2008 | 09:57 PM
Xeno's Avatar
so no real wait time? just pull, reinstall, and your good to go?
that'll help (every time I have disconnected my battery my car alarm went off )
Old May 11, 2008 | 06:53 AM
good info
Old May 11, 2008 | 10:37 AM
Arrow's Avatar
My radio presets never go away.
I've even had the battery and alternator replaced, with the battery out for over an hour.
Me thinks there's a secret SECOND battery hidden in the car...right next to that hidden GPS unit that controls our minds and tells the government how much gas we buy!
Old May 11, 2008 | 12:31 PM
losamigo's Avatar
Time wait would be the same, maybe a minute to be safe. Also should be done with the key off.
Old May 11, 2008 | 03:06 PM
red454's Avatar
Does this also clear error / CEL (check engine) codes?
Old May 12, 2008 | 04:44 PM
losamigo's Avatar
On some vehicles, a power fail it will clear stored codes. Not the case for the '05 & up Mustangs. These codes are stored in non-volatile memory.
Old May 12, 2008 | 04:55 PM
red454's Avatar
Ok - that is what I figured. Thanks -
PonyMuscletang13
Sep 26, 2015 02:33 PM
Allen Hanback
Sep 14, 2015 04:37 PM
Peacemakertransport
Fast Lane
Jul 11, 2015 08:33 PM
