06 Mustang GT popping sound HELP!!
Old Feb 16, 2012 | 08:39 PM
Zaksgt's Avatar
I have a 06 mustang gt with 89,000 miles and when I driving slow and usually turning I can hear a fairly loud popping sound. It sounds like it's coming from underneath the car somewhere. But when I crawled under the car to look I couldn't see anything out of the ordinary. I was thinking maybe bushings?? I just replaced the shocks and struts and all the lug nuts are tight. Thanks for the help.
Old Feb 16, 2012 | 11:37 PM
Zaksgt's Avatar
Anyone?
Old Feb 17, 2012 | 04:04 AM
Pete07GT's Avatar
Any suspension mods? My first guess will be the camber plates! My car is doing the exact same thing as this BUT it's because I have wicked stiff suspension that's need lowered WITHOUT struts and shocks. If it isn't your camber plates then I'm going to say it is probably your struts. The suspension on these S197's will only hold up to so much abuse before beginning to go out.
Old Feb 17, 2012 | 05:14 AM
05YellowGT's Avatar
If it's coming from the front end it could be the upper strut mounts. A lot of us have had it happen early on and I replaced mine with the Steeda heavy duty ones and I've had no problems since ...
Old Feb 17, 2012 | 09:28 AM
Zaksgt's Avatar
I'm all stock suspension, I just changed the struts and shocks to Koni yellow, about 2 months ago.
Old Feb 17, 2012 | 10:00 AM
stupidgenius36's Avatar
Just Plain Rude!
Sounds like the strut popping TSB from back in the day...Could be the same problem. I'd double check the struts.
Old Feb 17, 2012 | 01:32 PM
SteedaBrandon's Avatar
Former Vendor
Thanks for the Steeda props!
Old Feb 17, 2012 | 02:11 PM
Bert's Avatar
just a SWAG with so little information to go on, but I'm guessing upper strut mounts also
the Koni's have more damping than the original struts and maybe that was enough to cause the failure in the mounts, since they are prone to that anyway
Old Feb 17, 2012 | 02:29 PM
Former Vendor
PM sent.
Old Feb 17, 2012 | 03:42 PM
check your ball joints as well as upper and lower control arms
Old Feb 21, 2012 | 09:18 PM
Bakerjd's Avatar
Did you reuse the stock strut mounts? From what I've gathered that's not a good idea and people often minimally upgrade to GT500 strut mounts to resolve that issue.
Old Feb 21, 2012 | 10:51 PM
Zaksgt's Avatar
I assume so, I took it to my local trustee mechanic to change the struts.
Old Feb 22, 2012 | 11:30 AM
Bert's Avatar
The GT500 mounts are about $100, I doubt he gave them to you free and you'd probably notice that in the bill . . . sounds like there is a good chance that might be it ; then again beware of internet mechanics and doctors!
Old Feb 22, 2012 | 11:33 AM
Flagstang's Avatar
Spam Connoisseur
I got هَبوب‎ed
also check how your springs are seated. If they are not seated they could cause this.
Old Feb 22, 2012 | 01:12 PM
Shotokan1509's Avatar
Sway bar endlinks are also a common culprit, hard to get them tight with some of the designs
Old Feb 24, 2012 | 03:58 PM
Cavero's Avatar
+1 That's what I'd suggest checking too. My strut mounts popped when I hit any bump, not just turning. My swaybar end links would make a loud noise somewhere between a 'pop' and a 'thunk' when I was in a low speed turn (or sometimes turning the wheel as I was parking), usually as I was changing direction. Sometimes I'd feel it through the footwell.
Old Feb 24, 2012 | 11:21 PM
Zaksgt's Avatar
How did you fix it?
Old Feb 25, 2012 | 04:39 AM
Cavero's Avatar
How did you fix it?
The nuts that hold the links to swaybar and the struts had basically become loose. I torqed them down to spec.
Old Feb 25, 2012 | 10:52 AM
Zaksgt's Avatar
Thanks, now I have something to do tomorrow lol
Jim74656
May 1, 2023 02:15 AM
apial
Sep 6, 2015 10:40 AM
Mackitude
Aug 13, 2015 01:05 PM
HMR-TYM
Jul 31, 2015 10:39 AM
Mustang1987
Jul 8, 2015 11:21 AM
