Track times advice on lower times
Old Apr 9, 2012 | 11:44 AM
01bullitt's Avatar
I have a 2oo1 bullitt with o/r x pipe and intake went 13.91@100 with a 2.15 6oft want to get low 13's whats best way to get there
Old Apr 9, 2012 | 12:01 PM
1999Pony's Avatar
To start, subframe connectors, drag tires, and lca's. Then I would start on the power mods: longtubes and full bolt ons. Or you could just supercharge it.
Old Apr 9, 2012 | 12:06 PM
01bullitt's Avatar
I have subframe.connectors they came stock on bullitts and do lcas really help out that much
Old Apr 9, 2012 | 06:50 PM
tj@steeda's Avatar
Yes LCA's help keep that power transfered to the ground. Check this set up out on our Steeda car tjhat saw 10s at the spring break shoot out.
https://themustangsource.com/f726/st...ootout-506042/
If you are interested we can start talking packages that will get you to your goal of reducing your track time.
PM and let me know your thoughts?
Best Regards,
TJ
Old Apr 15, 2012 | 08:34 PM
fordracer's Avatar
Lower and upper control arms make such a big difference. Also try light weight wheels and a drag radial.
Old Apr 16, 2012 | 09:19 AM
01bullitt's Avatar
I ran again went 13.61@103
Want to do 4.10 tuner and lca then should be having alot of fun
Old Apr 16, 2012 | 09:12 PM
conv_stang's Avatar
raise the hood between runs to allow the engine to cool. Lower the air pressure in the rear tires. If you are running on street tires, don't do a massive burnout. Just a nice quick one to clean off the tires. Street tires get greasy with big smoky burnouts. And work on your launch...you are leaving .2-.3 of a second with a 2.16 60ft.
Old Apr 17, 2012 | 06:51 AM
01bullitt's Avatar
I war running 25psi in rear and cut a 2.o 6oft last time when I went 13.6
Old Apr 17, 2012 | 10:34 AM
Miserable's Avatar
Lowering your PSI a bit in the rear might help a bit.
I'm running 13:20's with my GT with the mods in my sig plus SFC, LCA, strange adjustable rears, Lakewood 90/10 fronts on coil overs, drag radials on stock rims and 4:10's.
Jim74656
May 1, 2023 02:15 AM
jc46002003
Apr 15, 2016 03:00 PM
5.M0NSTER
26
Sep 28, 2015 07:11 PM
ClayP
Aug 3, 2015 09:00 PM
Bert
Jul 25, 2015 02:13 PM
