Nitrous vs super charger
I would think so. The supercharger is constant power an with a good tune plenty more constant power. You don't have to refill it an its just all around bad a. I'm not sure where your from either but where I live a hooked up bottle can get your car taken away. While I don't currently have a s/c I know plenty that do an believe you'd be happier with a big ol Kenne belle whining under your Hood.
Yea I know my friend has 03 cobra stock s/c and it sounds nice, and is real quick but I was worried because my car has 150,000 miles already and all that extra power always running might shorten the life of the motor no?
True but then again nitrous from what I've heard is bad to some extent even on a fresh motor. I might be wrong. With either one I'd do a compression check an check all the internals out beforehand to make sure it can handle it
Boost is better than the bottle bar none. If I could afford to finish my boost project my bottle would be gone. Jmo
www.**********
www.**********
PonyMuscletang13
9/29/15 09:40 AM
