max lift i can run with a cam on '02 GT?
Stubborn Bear
TMS Staff
TMS Staff
I believe all of the aftermarket cams stay at a .550 lift for modulars. You will want to check with a cam manuf. on what they offer and specs they have. Comp Cams and VT Engines are both very reputible makers for the SOHC 4.6
Stubborn Bear
TMS Staff
TMS Staff
Im going on a limb and saying its gonna be at least $800 in labor from what I have seen in most shops. A 4.6L headpull and replace isnt a pleasing task.
PM svopaul. im sure he'd be glad to help you. but its gonna be up there. anderson ford motorsport makes a tool that keeps you from having to remove the front engine dress. but i can imagine its not the easiest tool to use
how hard of a job is it, do you have to do any valve work or anything or is it just a pain in the...bolt in? because my father and i are pretty handy with a wrench we just arnt professional...if its a metter of pulling parts off then we could do it but aligning the cam is what gets me, becuase i dont want any valce-piston clearance issues....i've been thinking about putting a stroker kit on it ( mainly for the forged internals the added ci's are just a big bonus) would you guys suggest just waiting and doing the stroker kti at the shop at the same time as the head/cam swap?
Stubborn Bear
TMS Staff
TMS Staff
You have to pull the heads off the car, which involves removing hte front timing cover (the entire size of the engine). Depending on the cams, stange 1 can usually use stock springs and valves, but anything bigger, I would defintely suggest new springs, as valve float is a possibility at higher RPM's. Talk to the cam manuf. and they can give you a better details on what is involved with teh swap.
If you are doing a stroker kit, just wait and do it all at once since you will have the motor out anyways. I've pulled a head off a 00 gt and it isnt fun.
