Low oil pressure
Old Apr 17, 2013 | 03:50 PM
ArmandoLuna's Avatar
Low oil pressure
So I recently did an oil change on my 94 gt. which was like two days ago. Before my oil pressure was normal all the time. Now since I changed it, it reads low. I put five quarts of oil. And the dipstick is full. Any thoughts?
Old Apr 17, 2013 | 05:15 PM
1999Pony's Avatar
What grade oil did you use?
Old Apr 17, 2013 | 05:19 PM
AlsCobra's Avatar
A Man Just Needs Some....
How long have you had the car? How many times have you changed the oil in it?
Old Apr 17, 2013 | 05:40 PM
Only had the car for about a month. This is its first oil change by me. The previous owner used vavoline all the time along with a vavoline filter. I put some pinzoil and a Bosch filter. I thought I was upgrading.
Old Apr 17, 2013 | 05:45 PM
AlsCobra's Avatar
He probably ran a thicker oil. Just try a heavier grade oil in it. It just means the clearances in your motor are wearing out a little. How low is it showing?
Old Apr 17, 2013 | 05:50 PM
Evil_Capri's Avatar
Could be a bad gauge too.
Old Apr 17, 2013 | 05:58 PM
I used 10-30
Not sure what it had in before
It's between low and normal.
In the middle
Old Apr 17, 2013 | 07:26 PM
AlsCobra's Avatar
I used 10-30
In the middle
Does it drop when you rev it or drive it in any way? As long as it doesn't get in the low range its safe. I would try a heavier oil anyways though.
Old Apr 17, 2013 | 07:31 PM
It did feel like the revs dropped a little when I was taking off out of the driveway. What kind of weight should I go with ?
Old Apr 17, 2013 | 07:38 PM
AlsCobra's Avatar
Might want to ask the guy you bought it from what he used to run. I would really hate to recommend one since I am no oil expert.
Old Apr 17, 2013 | 11:04 PM
bluethunderhorse's Avatar
Change to a different oil filter Bosch and Fram killed the oil pressure in my old 94 5.0. With a motorcraft filter the gauge would be on the M of normal, Fram and Bosch it would be on the O
Old Apr 18, 2013 | 09:25 AM
1999Pony's Avatar
This is what I would try first.
I don't feel like that would be much of a problem. I know you experienced it but I just don't see it being a common issue.
Old Apr 18, 2013 | 09:41 AM
It has happened on my moms explorer, my step dad's sport track, and my friend's mustang. That's why we only run a motorcraft filter
Old Apr 18, 2013 | 03:57 PM
1999Pony's Avatar
****, don't blame you. I've never had a problem, but then again, I only run motocraft anyway.
Old Apr 19, 2013 | 10:02 AM
Better run what ford recommends I guess.
Old Apr 19, 2013 | 10:18 AM
muscledom's Avatar
Could be the wrong filter
southern stang
Sep 26, 2015 04:19 PM
Jailbirdwatcher
Sep 25, 2015 06:39 AM
oldnjguy
Sep 10, 2015 02:39 PM
